C6 Full Bi LED Morimoto C7 Style Replacement Headlights from Umnitza WITH photos and
#541
Supporting Vendor
We should have some photos of the artic white shortly.
Need to provide an update - starting sometime this weekend - but most likely Monday - you will be able to purchase the same type of DRL harness that gives you the functionality you were talking about in a plug and play set up for about $75.
We're still ironing out the pricing, but the pre-order customers that ordered the headlights will get FIRST dibs regardless of when you purchase. If you purchased the headlights from another party, you will still be able to purchase it at this price but will be given second priority over our own headlight customers first.
- Will link when ready to pre-order. Availability will likely be mid next month or sooner.
#544
Fred
#545
antidookie (09-25-2018)
#549
Supporting Vendor
It will plug between the headlight and the OE plug. It will allow for the "L" hockey stick to operate in full 100% brightness for DRL functionality and still allow you to flash the low beam if you are doing the flash to pass feature. It will basically activate the "L" instead of the amber signals that are normally activated for DRL functionality (at least this is what we're told until we get to test it, we won't be certain). I should have one air'ed over here as soon as it's available, and I suspect Coupe89 will be the first over here because he's been so gracious to give us his car for testing every time (Todd).
See you for the harness testing, will contact once in hand.
BTW a few of you have commented that you're not getting as quick a reply as you were when we were doing the pre-order, I apologize. we're actually in the middle of a lot of changes to our product line database AND have many group buys for other products going on now as well.
Please be patient
#552
2023 C5 of the Year Winner - Modified
2023 Corvette of the Year Finalist (C8) - Modified
2023 Corvette of the Year Finalist (C6) - Modified
2022 C8 of the Year Winner - Modified
2022 C6 of the Year Winner - Modified
Finally installed mine!
#553
Is it only me who thinks it looks really stupid on cars that have white LED DRL's that turn OFF when the amber turn signal flashes and the other side white DRL is still on???
#558
#560
