C6 Full Bi LED Morimoto C7 Style Replacement Headlights from Umnitza WITH photos and
#42
I just want to give everyone a heads up regarding these lights. I was sold on these lights and had a pending order until I discovered that the "L" shaped light is NOT the DRL. The DRLs are actually the amber lights on the outside of the lights. The "L" shaped light is actually the parking light and only comes on with the headlights or when exterior lights are on.
I feel as if the pics were deceiving, but I in no way blame any of the vendors. They worked with what they had.
This might not matter to some, but I know it really soured me on the purchase. I'm not trying to stop any sales, but I want to give everyone a heads up because I know I would appreciate it.
#43
Supporting Vendor
Nothing on your car is a DRL currently unless it's programmed that way. So all we have to do...well I won't give away what we have to do, but when we install them, we'll be able to do more with the lights than what you are describing.
#44
Fixed what you mentioned, but what do the vast majority of customers do who are not going to have them installed by you? Can you provide info via PM?
GingerGranny (06-19-2018)
#51
I ordered a pair under the impression that the "L" were already set up as DRL........I'm going to be more than bummed if this is not the case and if I can't get them set as DRL
#53
Supporting Vendor
Let's keep it to the PMs ok?
#54
I ordered a pair under the impression that the "L" were already set up as DRL........I'm going to be more than bummed if this is not the case and if I can't get them set as DRL[/QUOTE]
I would like to know this as well!
#55
I would like to know this as well![/QUOTE]
These are the DRL that happens when plug and play .. There are 2 sets of wires that run out the back. I know one runs the sequence turn and the other the L LED .. I
The following 2 users liked this post by Caveman74:
Twin6s (06-20-2018),
Z28ImpalaSS (06-19-2018)
#58
O.K. I did re-read another post on these lights and it states that the AMBER Sequential lights (Blinkers) on the outer edge are the DRL's. The "L" shaped light comes on with Parking and/or Headlights. I really thought and was hoping the "L" shape was the DRL. Kinda Bummed about that.
May have to rethink purchase unless this can be made to work so that "L" shape is DRL, and Amber are simply turn signals/parking lights.
The following 3 users liked this post by info@umnitza.com:
#60
Umnitza,
Thanks for all of your help on these lights!
info@umnitza.com (06-20-2018)
