Parasitic Draw
1 Post
Parasitic Draw
My battery keep dying. I had a friend check it and he said I have a parasitic draw that’s why the battery keeps dying. Some module is drawing power but doesn’t know where. It would not code. Any ideas ? I have a 2010 C6 Grand Sport. Also, I have a squealing noise he thinks it’s the pulley. The crankshaft is wobbly. Possibly related ? Thank you.
Received 3,066 Likes
2021 C6 of the Year Finalist - Modified
Same problem with my 2011 GS.
Pull the OnStar fuse (located in the passenger side footwell area fuse panel) and I bet your electrical parasitic draw goes down to next to nothing.
You can read all about my problem here, plus the fix .... https://www.corvetteforum.com/forums...ead-again.html
________________________________
As far as the wobbling pulley .... You are going to need to replace the Harmonic Balancer (common problem with the LSx engines)
Landru (06-19-2018)
