Update: Limp Mode after accelerating quickly. Codes:P1516 & P2101.
Hi yall. Thanks for looking.
my C6 still goes into limp mode after mashing down on gas..otherwise it drives fine.
Per the forums suggestions heres what I've done:
*checked out for leaks in throttle body and intake manifold
*changed throttle body
*changed gas pedal
*disconnected battery over night...
so I'm beyond tired on this....I'm about to take it to the shop...
anything else I can try? Thanks
*changed gas pedal
Received 2,882 Likes
After you changed the TB did you have a reset done? My dealership charged $75 to do it. It will relearn as you drive but might take quite some time as it only does so under specific conditions.
Google it and you can find the instructions for a reset test drive. I could not get it to work so had the dealer reset it.
Biggie G (06-26-2018)
Ah good tip
But I dont think the new throttle body fixed the issue as the car is having the same issues....
I'll give it a try thou thanks
I'm also going to autozone again to get the codes read
Fyi....same codes appear....
I'm gonna do the throttle body relearn next
Update: Throttle Relearn procedure complete-no change in codes or Limp Mode
I've been focusing on the Harness that connects to the Throttle Body.....I will be replacing the harness and hope for the best.
Any input would be appreciated. thanks
Spray the connections with an electronics or similiar spray, cycle the conector 6x just dont clip it in final position. This may help get any corrosion cleared, spray agian then a final plug in.
Thank you Sir, will do!
Whats annoying is that, She drives fine until I punch it....
Did you try the MAF swap?
When I changed my TB was having same problem. Turned out to be the MAF sensor, then needed the TB relearn. All back to normal now. All this from cleaning the TB.
Warning do not open the TB by hand.
Biggie G (06-28-2018)
interesting...I gonna give this a try if if the throttle body harness doesnt work (I ordered one-it's in the mail). thanks
Good luck, keeps us posted.
Thanks bud....lets hope for the best
I swapped out the throttle body harness ......it didn't work.
I'm gonna swap the maf next as I'm some whatout of options
Update: Still going into Limp Mode
but I was damn surprised how much better shes running after I replaced the MAF...do these things wear out or something? lol
Im gonna take it to a dealer.....FTL
