C6 427 60th Anniversary - motor failure
I turned 60 on June 20th, I had a specialty plate made 'MY60TH'. I really wanted the 60th anniversary corvette. I saw this car and said, let me just do it. I hesitated on the warranty at first because of the low miles, but I figured many things on the corvette could be expensive and I thought the warranty (bumper to bumper) was reasonably priced and is transferable for a $45 fee. So I went with the warranty to make me feel comfortable about the purchase. I reviewed the contract last night and I did not see anything in the fine print that should make me concerned. I have driven the car to a few car shows, and stepped on the gas a few times to bring back that smile I had when I was younger, but that is all. You guys have been a real help, and these posts help keep me optimistic. I will be touching base with the chevy service department today to see how the job is going. I will keep you all updated. Thanks again!!.
Landru (06-26-2018)
Good luck, hope you get it all sorted. I did the exact same thing a little over two years ago, bought a 60th anniversary GS for my 60th birthday. I had been thinking I wanted a velocity yellow one until I saw the 60th anniversary package.
Good luck! I know a couple 13 427 motors that blew. Definitely make sure they replace every part of the oil system as mentioned before as the new motor will die also. I'm guessing it is the rod issue that is common. For some reason GM screwed up building some of them, which ones is always the question. I heard good things about car max. I know I wouldn't buy an LS7 without an extended warranty. Getting on it a few times is not an issue so I wouldn't worry about that too much.
Buying used is always a risk because you don't know why they are getting rid of the car in most cases.
Good luck with the repair. It figures that GM won't cover this issue out of warranty, it even involves some patience to get them to cover it within warranty as they'll look for a way out.
Speaking from first hand experience, since the car is out of the 36 month warranty there is no GM participation in the fix. GM Customer Service will listen to you and file an incident report but that will be the end of their interest. Very disappointing the position that GM takes on known issues and low milage failures but that is what we have to live with. The fix is out of your pocket.
Look back & see when the car was sold to the first owner. That starts the "clock" for the 5year/100,00 mile power train warranty. I bought mine last May (427 CE convertible) & it still has a full year left so I'm having mine looked at soon at my Chev. dealer.
Good point, I will try to find the in service date. Thankyou!
Pro Mechanic
Received 3,952 Likes
I checked the in service date on the car and it was January 2013. The car showed up in the my search at CarMax the first week of February, just over 5 year warranty. It had just turned over 6,000 miles so the previous owner may have just had the oil changed. CarMax informed me that they had also changed the oil. Shortly after I purchased the vette, I had an issue with the car starting when it the engine was hot. Thought it might have been the battery because a battery charger was left in the trunk. I checked the battery and it was only a few months old. After a couple weeks it got worse and so I brought it to the Chevy dealership. They battery checked out OK. They found that the starter required an allot of amps when the engine was hot, so they replaced the starter and CarMax covered it. After that it started fine for awhile and then it started to hesitate again when hot. I mentioned this to the service dept again when I brought the vette in for this issue. They stated that in some cases hard starting could also indicate a bearing issue.
Chevy dealership was hoping to start the tear down today.
Landru (06-28-2018)
Received 3,625 Likes
2016 C6 of Year Finalist
As has already been said...
Make sure everything that had oil going through it is replaced...
my60th (06-27-2018)
Thanks I will. I intend to to inform the service manager how critical this is. The dealership has been great, and they have brought the mechanic out to talk to me several times. I will be sure to have a conversation with him on this also.
Received 1,090 Likes
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
You've been very calm and even keeled so far and I applaud you for that.
I sincerely hope everything gets worked out to your satisfaction.
They will probably let you keep the old motor if you ask - do it. You're block may or may be salvagable, at the least you'll likely need new Ti rods. Might be able to make a hot-rod out of the old motor or sell it for parts. Too much fun to let someone else play with it. At the least it would make a badass coffee table with a glass top on it. Tell them that is the least they can do for your inconvenience. The original heads will be ideal cores send out and "fixed" for the valve guides while the new motor gets installed. Look in the Z06 forum for more info, but consider American Heritage Performance in Harbor City, California. https://www.americanheritageperformance.com/
#34
I've never heard definitively but from what I have gathered, GM tried to use a new main bearing material that was more environmentally correct for import over to Europe. Obviously they soon realized the mistake that that was but I've never been able to narrow down specifically when they started doing this, and when they stopped. I don't believe any 2012's had these bad bearings and I don't believe any of the 2014 Z/28's had these issues, either.
I'd like to learn at what point (if any) in the 2013 LS7 production run did GM switch to the previous bearings? Why does this happen on some motors and not others? I remember back when the 427 Vert's were new hearing about motors that gave out before they even got to their first 1,000 mile interval. Lots of folks spent a lot of money on a sweet one-off for 2013 Corvette and got stuck with a bum motor. I always wanted one but was hesitant for this specific reason. Heads (valve guides) I could fix, main bearings taking out Ti connecting rods, out of warranty on my dime, no thank you.
#35
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
I'm glad the OP is getting some progress and hopefully it will all be fixed, maybe even a new engine vs. a reman engine. And, while the car's original powertrain warranty ended this past January, I learned from that thread I included in my other post that CarMax's warranty is pretty darned good, too. Even tho I've sold a few cars to them, I've never bought---these examples could change my mind. I'll wait to see the final outcome for and of the OP's car in this thread but it definitely seems like it's going in the right direction.
Thanks for keeping us updated and continued good luck!
#37
When I bought my 13 GS brand new I seriously considered the 427, but went with a GS, as the Z06's also with the LS7 were already having some catastrophic failures.
This was surprising to me as all those motors were "handbuilt" at the Wixom facility and came with a signed engine plaque by the builder.
Although some say the number of actual problems is low, the total number LS7's sold is low too, so the actual percentage may be significant. This is why
I think someone with one of these failed motor should open up a complaint with the NHSTA. GM may not want to help here, but the government may feel differently.
I say this because several years ago our Mazda suffered an out-of warranty axle failure, coasting in a parking lot, which cost us almost $3000 to repair. If we had been on the highway
we could have lost control, flipped, been injured or killed. The vehicle had been serviced regularly at the dealer, garaged and kept in perfect condition so I asked Mazda to cover this and was denied.
I contacted the NHSTA to file a complaint about a possible safety defect . . . . they opened a file and assigned an intern ( a kid from University of Michigan ) to research it . . .
turned out there others with the same exact issue, apparently due to premature corrosion from road salt. Mazda had to recall thousands of vehicles in states where salt is used to inspect or replace
the axles and boots, which cost them millions, and we got all our money back as well. And that intern was so proud of his work.
There was already a lawsuit ( https://www.leftlanenews.com/corvett...ems-89973.html ). Maybe its time a government summer intern look into this LS7 situation.
Good luck to you.
Good luck to you.
#38
Received 1,678 Likes
2018 C6 of Year Finalist
St. Jude Donor '10, '17
Maybe its time a government summer intern look into this LS7 situation. Good luck to you.
#40
Received 1,136 Likes
I say this because several years ago our Mazda suffered an out-of warranty axle failure, coasting in a parking lot, which cost us almost $3000 to repair. If we had been on the highway we could have lost control, flipped, been injured or killed. The vehicle had been serviced regularly at the dealer, garaged and kept in perfect condition so I asked Mazda to cover this and was denied.
I contacted the NHSTA to file a complaint about a possible safety defect . . . . they opened a file and assigned an intern ( a kid from University of Michigan ) to research it . . . turned out there others with the same exact issue, apparently due to premature corrosion from road salt. Mazda had to recall thousands of vehicles in states where salt is used to inspect or replace the axles and boots, which cost them millions, and we got all our money back as well. And that intern was so proud of his work.
Good luck to you.
Good luck to you.
My 2017 truck, which has been through two winters, already has signs of rust on the undercarriage.
