Nav malfunction
Old Jun 30, 2018 | 09:40 AM
ragweed's Avatar
ragweed
Default Nav malfunction
A little box with "MAP DVD READ ERROR" keeps popping up on the nav screen. Anyone know the cause?
Old Jun 30, 2018 | 10:05 AM
EVRose's Avatar
EVRose
The message sounds pretty self explanatory to me. Eject the disc, clean it and try again.
Old Jun 30, 2018 | 11:07 AM
Kenny94945's Avatar
Kenny94945
IMO high probability the map reader laser lens is dirty.
A cleaning disk may help, but disassembly of Radio/ Nav unit so you can physically clean the lens may be the answer.
Also canned air and a vacuum (suck out the dust) may help.
This is burdensome task, I've done it.
Try a search for radio/ nav unit disassembly.
Hardest issue in disassembly for me was the screen removal, I could not disconnect the screen to unit wiring connector.
There is also a copper ground (in an upper corner) that can be fragile.
Good luck.
To Nav malfunction
