My nightmare - need recommendation!
Well, about 3 months into ownership and catastrophe has struck. While driving 55 mph this past Sunday I had a sudden loud engine squeal and it started running terribly. Long story but had it towed to local Chevy dealer. They just called confirming a lifter is bad.
It's a 2008 base with BTR stage 4 cam. They're saying the lifter doesn't show any signs of damage, so the thinking is the cam is ok. But they'll still need to confirm that.
So, change out all the lifters - $4k with 2 year warranty on the parts/labor.
Or engine swap (their idea for an option) - $8k. That's a brand new LS3 with 5 year/100k warranty. No custom cam after that.
I'm looking for options. Does anyone have any recommendations for a performance shop in the north Florida area? Anywhere I can get some ideas, alternatives, help.... whatever?
Tough call. How is your financial situation?
Is it possible a 'bad lifter' shows 'no damage'?
I mean if it's 'bad', right?
How long you'd planned owning this car would dictate course, for me.
Long term maybe invest the $8 large on a new LS3.
OTOH if planning to turn it over soon address lifter(s) at half the cost, then flip.
G/L w/ decision, update thread which way's chosen.
Received 1,136 Likes
Especially: "They're saying the lifter doesn't show any signs of damage, so the thinking is the cam is ok."
So if the lifters and cam are okay, what *IS* wrong with the engine?
Thanks guys, the financial situation it tight when going with the engine replacement mainly due to some other plans I had this year. But it's not going to kill me either way.
The cam is obviously fun, loud and I'd miss it. But there may be another option. GM has a LS376/480 option. It's an LS3 cammed from the factory with 480HP. Dealer said same warranty applies. I've got to get their price on that and that might be the choice.
I have cold intake, headers, x pipe and 3 inch into Borla S-Type II, so it might still be close to what it is now.
https://www.gmperformancemotor.com/parts/19369333.html
The squel sound is the lifter bearing. We know that. They're saying they haven't seen anything to think there's cam damage, but really without a visual inspection there's no way to know for sure. Problem is there's a lot of work to get to the cam and if there is damage, labor costs to get that far along with a new cam just got me cost close to the engine replacement cost. So it's a gamble.
Of course, all of this is over the phone and I've not been able to to inspect anything myself. So I'm taking their word. I've been using this dealership for years and I have as much trust in them as you can have in a dealership. For whatever that's worth....
Well, the LS376/480 isn't an option now.... the cost for that just went up to $12k. Nowhere near worth it. I need to find another shop to talk to.
Received 3,611 Likes
2016 C6 of Year Finalist
If you put a new engine in, you’ll be upside down... an 08 is only worth 22k or so. Get more opinions. Find you least expensive repair. Your at the tipping point in respect to making serious/expensive repairs to a decade old C6
Personally I'm skeptical of the diagnosis. These days most dealer shops are parts swappers, they're used to doing warranty work where they don't even bother to diagnose, they just drop in a replacement crate engine and send the bad lump off to GM to be remanufactured. I would find a reputable indie who does in-house LS rebuilds on a regular basis. They may find the actual problem and it might not cost that much to fix. WIth an indie there would also be the option of dropping in a used engine, which I don't think a dealer will do. And even if you went with a crate engine, the labor would still be less at an indie. Worst-case you could part it out or sell it as a roller to someone wanting to build a track car.
The following 2 users liked this post by ben z:
corvette312 (08-27-2018),
JerriVette (08-26-2018)
If there's no damage to the lifter bores, lifters or cam, how can they be sure that was the actual cause of the failure. How was this diagnosis achieved? Were the heads removed? Compression check? Oil checked for particles? Etc etc.
We're not getting the whole of the story here. If a lifter bearing failed, it usually takes out the cam at minimum, commonly the lifter bore and pushrod as well. Occasionally the rocker and valve spring. If the heads were removed it's generally a more reliable diagnosis, if they weren't then I wouldn't trust any diagnosis.
Either way, I'd take it somewhere else.
I they repair it is the 2 year warranty on the complete engine or just the lifters? If somehow they warranty the engine I’d repair it and keep the cam.
