Chevy Stealer??
Chevy Stealer??
Hello Everyone.Had a intermittened charging issue..New battery, Alternator fine..Brought to dealer.Told my balancer was shot..1890$ bill..Said no thanks...Took it home and found the bolt had loosened off..They didn 't even both to check!! Belt slipping = no charge..Will never go back again!
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
Interesting. But would be more helpful if you said where dealer located AND the name (since you're never going back). Thanks. Good luck.
If you have the knowledge of how to diagnose the problem and fix it, why go to the dealer to begin with for a non-warranty problem. It would be interesting to check back next month to see if the "fix" holds.
St. Jude Donor '15
"In honor of jpee"
Ah, the Far North! I went to a great Corvette show in Ontario a year ago. Mike Jackson Chevrolet's annual show.
I'm sure there are more dealers, but you may have to "go across the bridge to a dealer in Dearborn." j/k, of course, since it's a ride to get there.
Did you check to see if the rubber is separating from the pulley? If your harmonic balancer is on the way out, you may hear a squeaking noise, and the pulley will have a wobble to it due to the rubber separating from the pulley which will cause belt slippage. A friend had his C6 Corvette harmonic balancer pulley replaced because it was displaying the problems above. Cost was about $1500 a few years ago.
What year is your car?
Received 5,207 Likes
Was the price in Canadian dollars? Just curious since I had the notoriously wonky vibration damper on my C5 replaced a year ago, along with a bunch of other things I'd put off doing myself, and the entire bill was less than yours in US dollars. That wa at a dealer who sells and services quite a few Vettes (for my area) and seemed to know what they were doing.
Id be pulling that apart and inspecting the crank and the inside of the balancer. You may have damaged either one or both.
Good luck with the repair! HBs fails are quite common. I would research about replacing it with ATI or something just in case you need to replace. it. If the GM dealer is charging you MSRP for the parts then that could explain the high price. I always try to negotiate. Dealer can't tell me that he needs to double the price what certain dealers will sell you the part for just to make money. Labor prices you can't do crap about unless you know someone that can do the work.
Received 3,625 Likes
2016 C6 of Year Finalist
Correct me if I'm wrong but a loose HB bolt will not impact charging...unless the HB has worn the snout down to where it slips.
with the bolt loose the hb could be spinning on the crank snout.that is what spins your alternator so it can impact charging with alternator not getting up to speed to keep battery charged.hb spinning on crank snout will destroy the crank
when their spinning they stay on till they start wearing the crank snout.then all kinds of bad things happen.the belt comes off and hb can go backwards into timing cover or forwards into steering rack.at that point you just need to remove engine and replace crank and everything else that has been damaged.why do you think we pin the hb to the crank?
