2013 carpeting detached from console
I'm guessing this is a common occurrence, probably because the console gets very warm. but passenger side carpeting is coming apart from the console, not sure how its supposed to be attached? glue? anyone have this problem? suggestions? thx.
Keith
Keith
It wasn't "common" but there were quite a few cases reported here over the years.
Here's just one example discussion with some ideas to consider:
https://www.corvetteforum.com/forums...y-console.html
Received 8,805 Likes
Mine was sticking out from the rear of the center console - the carpet is too short. I did find if I tightened down the rear of the console more (two screws inside at the rear under plastic caps) it holds the carpet under better.
My '13 GS has shrunk so bad glue wouldn't help, Carpet needs to be 3/4" longer. It bugs the crap out of me as it's the only thing not right about the car. If the carpet was replaced, I'm sure it would shrink too.
