Front skid plate wheels
JoeM,
Check these out from Protekt. I have them on my C6 and they work great. Also had the Fangs on a C5 that I had and they worked great too. Maybe a combination of both on your C6 would work, but I could see the cost adding up. Hope this helps.
https://www.corvetteforum.com/forums...ase-model.html
JoeMatilda (07-21-2018)
Friends,
I have been enjoying the hell out of my C6 for almost a month. However, my driveway is killing the bottom of the front bumper. I've tried entering/exiting the driveway at an angle, and it helps, but it still getting a scratched bottom bumper no matter what I do. A buddy of mine just suggested these Front Skid Plate Wheels by West Coast Corvette.
Does anybody have experience with them? Are they worth buying? Any other suggestions??
Many thanks in advance.
https://www.westcoastcorvette.com/p-...te-wheels.aspx
Ok, thanks for the responses.
I just got under the car and noticed that the plastic under the nose, around the spoiler, is scratched. I also noticed that the radiator supports are VERY scratched. Part of my problem now is that I can't tell which scratches are mine and which ones were made by the previous owner. My plan now is to move the car to the edge of the driveway and try to see what part is actually rubbing against the pavement. If it's the radiator supports that are touching the ground, then I will look into those "Fangs" as See5See6 suggested. If It's the plastic next to the spoiler, I will try to enter the driveway from the North instead of the South as I do now. Hopefully the different angle will help.
your suggestions have given me a couple of things to look for as well as more options. Many thanks!
I will let you know what I find out and what I do about it.
JoeM,
Many thanks! Another great alternative!! I like it!!
In the last couple of days, I've wanted to go out to the garage/driveway and figure out what part of the car is touching the ground. My DD thermometer was showing 113 degrees in the street when I got home from work... Lol
(Dont worry, it's dry heat..... NOT) hahaha. May have to wait a couple more days to figure it out. You guys are giving me some great ideas!!
Supporting Vendor
Just a FYI to be clear, the ProTEKt Skid Plates protect the body and the Fangs protect the Lower radiator support/Skid bars.
Christian
Christian
Supporting Vendor
Bump for the Fangs!
Protect your lower radiator support/Skid plates with anti friction Fangs and only loose 1/8" of ground clearance.
Available for C5 and C6 Corvettes.
https://www.saccitycorvette.com/C6-Fangs.html
Thank you ,
Christian
Thank you ,
Christian
