rubbing noise.
rubbing noise.
2010 LS3/C6; Just purchased car....love it! Except for, loud "rubbing noise" coming from front corners where hardtop and windshield meet. Tried a small strip of rubber weather striping on bothe sides; only minimal help. Any suggestions? Thanks.
From there, here is the long version of O-rings, dialectical grease on the seals.contact areas, and installing C clips on the lock rollers to make sure you don't get noise from the roof.
https://www.corvetteforum.com/forums...long-post.html
Rubbing noise.
Start by pulling the roof to make sure that the hardware on the roof is tight.
Thank you for the advice....I will let you know how it works.
Thanks again.
Try adding larger O rings to the two pins I did that and it helped with some cracking noise
Thanks again........much appreciated!
