C6 won't start reduced engine power service TC SYSTEM ANTI LOCK BRAKES what can I do?
C6 won't start says reduced engine power , SERVICE TC SYSTEM, service TRACCTION HANDLING SYSTEM and ANTI LOCK BRAKES. It was driving fine the night before. This is so weird...it's an 07 with about 94000 min on it
if anyone could help I would gladly appreciate it.
Need to pull the DTC codes to get a idea of the real problem.
Check your spark plug wires. They have a habit of occasionally falling off the coil. Can be any of them. Will cause all the problems you described. Happened to me recently after 10 1/2 years of ownership. Good luck
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
a lot of times, a weak battery (even, in many examples, a brand new battery) can cause all kinds of problems. Do the above first, but tell us when you put in a new battery the last time?
