ExtremeOnlineStore | C6 Z06 Front Splitter Ground Effect - Best Price|Free Shipping
Supporting Vendor
Customer Review:
I ended up going with the raw ABS splitter and side skirts on ebay, they match the OEM plastic rear diffuser and other plastics perfectly. It was about $300 for the whole kit, at that price I'm not concerned about having to replace them down the road. I've had them on my car for two year now and look great. leaving them raw ABS I don't have to worry about rocks chipping the paint or when my passengers accidently scrape there feet on side skirts, which my wife does all the time, after 2 years there is no evidence of her shoe scraping. the fit was pretty decent, I didn't have to do any special modifications to fit, no gaps. The finish is somewhat textured like the rear diffuser.
That’s good to hear Rick. Apparently the shipment of my front splitter got hosed up at EOS...I’m hoping it will arrive perfect. I’ll post my experience once it is received.
Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
The package is top notch. Wrapped with foam and then in a box with supports and additional foam to keep it in place.
Received 3,066 Likes
2021 C6 of the Year Finalist - Modified
The ZR1 front splitter from Extreme Online is packaged very good ...
Here is how mine arrived at my house:
Supporting Vendor
Customer Review:
Corvette C6 Grand Sport / Z06 Front Splitter Lip & Side Skirts Rocker Panels
Extreme Online Store front splitter and side skirts. Just as they came like NSF posted above
Not pictured is the rear ZR1 spoiler from EOS as well.
QAS (06-02-2020)
Supporting Vendor
You order is currently in transit and the tracking number was sent to you through PM & email. Please let us know if you have any other questions.
Thanks. The link in the PM didn’t work and no email was ever received. I don’t appreciate the implication that the info was provided earlier when it wasn’t. Please just make sure the item has been shipped. I will provide an update for all when this purchase has been completed.
Supporting Vendor
Hooray! I received the splitter today. Hopefully it will go on without a hitch. It actually came with some instructions and screws for installation. A nice, unexpected, touch. Thanks EOS.
Supporting Vendor
Customer Review:
Corvette C6 Grand Sport / Z06 Front Splitter Lip & Side Skirts Rocker Panels $709.98
Supporting Vendor
Finally had a chance to install the replacement. Perfect fit and looks beautiful!
#33
Supporting Vendor
Customer Review:
I have both their carbon fiber splitter and side skirts. The pieces are decent and fit very well for the price. They are a bit flimsy/fragile. In order for them to meet my requirements I added fiberglass filler to the under side of all pieces to give them more strength. While CF is suppose to be light weight, in my opinion, they needed a bit more mass to make them stronger. Overall, they turned out looking pretty good and I am VERY picky. The hardest thing to overcome is drilling holes in your rocker panels. However, that's what GM did so I went for it. GM also used black pop rivets for installation. The skirts come with screws and if tightened too much they simply won't grip. I ended up using a different screw with a coarser thread because of that issue. The only reason I didn't use pop rivets is that I wanted to easily replace one if it got damaged and drilling out pop rivets is some what of a PITA. Hope this helps.
#34
I cannot say enough about this supplier. I originally ordered the complete set, splitter ZR1 spoiler and the side skirts. While the splitter never fit correctly, I never said anything and ordered a carbon fiber one for around $400. Took over 7 weeks to get it. I had the skirts on as well as the spoiler for some time and then pulled a bone head mistake and forgot I was parked next to a island and pulled out and kit the cure breaking the right side skirt. I went on line the next day and saw that EOS had side skirts for the base in the carbon fiber look. Order a new set and had then in less then 7 days. A perfect fit and now they match the front splitter. It would be nice if they came out with the ZR1 spoiler in the same finish. Foe now I am going to try and wrap it with the 3m carbon fiber look vinyl.
Not the best picture, because the car is in the garage covered but when I can I will get a few more pictures from different angles.
Final thought, if anyone is concerned about the products, because they are cheaper, if you drive the car daily, these are the way to go. They fit great, and if you do break then you can replace then and still be under what others charge for a set.
ExtremeOnlineStore (01-15-2019)
#36
Location: Retired early,everyday is Saturday...Hocking Hills Ohio
I purchased these side skirts from this vendor and couldn’t be happier. excellent fit/finish/quality! fast shipping to Ohio, over the top packing too. will do business w/them again...
#39
Supporting Vendor
https://extremeonlinestore.com/colle...nt=54331312139
https://extremeonlinestore.com/colle...nt=54907056395
