Clicking sound from front left wheel when turning left
So I just got this 2010 base vert last week and everything seems to be working fine.
But.....
I keep hearing a clicking sound from the front driver side when I turn left. It sounds similar to the old cv axles when the boot would go bad on a front wheel drive car but a little less exaggerated.
The previous owner said it had never been hit and it has a clean carfax history, alignment is fine and there's no other symptoms I can find currently.
What would cause this?
But.....
Retired & lovin' it!
But.....
But.....
But.....
But.....
While you have it jacked up, take the wheel off and clean the wheel and spindle where they contact each other. Be sure to re-torque the lugs in the order shown in your owners manual and at 100 ft-lbs. Had similar noise which proved to be dirt and grime build up on the mating surface of the wheel.
I drove through a pretty good rain storm on the way home from work tonight and the sound seems to have gone away.
If it remains gone through the weekend I'll report back that it must've gotten a good rinse in the rain.
If it comes back, I'll try cleaning the surfaces and get back to you afterwards.
Thanks again for your input.
Might have been a pebble or a nail head stuck in between the thread . Keep an eye out for a slow leak. Its happened to me. A slow unexplained loss of tire pressure when the nail head wears off
Clif
Clif
The noise is still gone 150 miles later.
I took a good look this weekend and didn't see anything remarkable.
I think whatever it was, it was rinsed out by driving through the rainstorm.
Thanks again to everybody for chiming in.
