No Tach/ Knock sensor
Hey, so I bought my first Vette about 2 months ago Haven't driven it a ton yet, but I've been having an issue and I'm hoping someone has heard of it before:
06Z 7.0l
When starting back up (after warm) sometimes it has real trouble starting as if the battery is dead. Then it will kick over, and instantly feels like there is a misfire and I have no tachometer. The first time it happened I limped it back to my office, still ran just felt like a misfire or something. I shut it down, let it sit for a minute, and when I started it back up I had the tach back and a light came on. Few days of it sitting in the garage I started it back up, everything was fine, no light, could recreated the problem. I got it inspected the following week and mentioned the problem. They said the code history showed a mass air flow as well as a knock sensor. They mentioned it could have been some bad gas to throw the knock sensor. However the tach losing all movement is weird. They cleared the codes, everything has been fine with it since this one hiccup, until last night when I got gas. Started it up (been driving for 20 min prior) and had this issue again.
I think its a fuel issue, maybe plugs are soaked or something? Previous owner said when I bought the car the only starting issue he ever had was that the starter was getting too hot, so they had built a shield around it. Apparently this is common on these cars? IF someone could confirm that, that would help too. Thanks, any input would help!
06Z 7.0l
I would like to revisit this thread as I am experiencing the same problem as described above. Does anyone know what is causing this problem. Seems very weird to me. All help or comments appreciated.
Jay
Jay
Plug and injector wires are all good.
I charged the battery and started the car and all seems to be ok again. I cannot believe that this could be related to a low battery. Charger is off now so I will see what happens next time I start it.
Jay
Jay
These cars get whacky when the battery is low or bad. Did you have to reindex your windows?In the future keep a battery tender on the battery when not in use. A TENDER......not a charger
Clif
Clif
Jay
