fish bite???
Using throttle body cleaner didn't cross your mind? Instead you used a caustic product designed for 30+ year-old technology? Alrighty then....I hope it works out okay for you....
Mine does this but it did not before I cammed it and since the few cars I've cammed all jerked a little at low speeds I've just accepted that it's the cam in this car as well.
iw172 (11-17-2018)
Hi guys !
Same problem here. C6 2008, manual. Fos a year, the problem is like very light.....When i try to show it to the mechanic, it's not bad enough for him to notice it. But i do ! When reading this, i also notice that i tend to feel it more when it is cold. Also, ususally a lower steady speed, like 30 MPH let's say in fouth.
So, i did what was explained in here. Cleaned the MAF sensor, and throttlebody (wich was vey dirty BTW). Mechanic scanned it (nothing came out), and re-initiate some parameters.
Tried it yesterday night....Same thing. maybe a bit worse when cold, not better for sure.
Mechanic told me that it could improve along the next weks as it might adjust. Any other thoughts ?
Thx, very interesting to see some other having the exact same trouble, wich are not very bad, but i feel it for sure.
Marc
Marc
Hi guys !
Marc
Marc
Did you have the mechanic do a relearn idle? as it gets dirtier that flap does not close all the way which lets a small amount of air in so you have to have it re-learn idle to go back to correct position. after that it helped mine quite a bit . also I didn’t know about the clutch fill reservoir and mine was practically empty so you may check that too .
Hi Vettev22,
yes, the mechanic also relearn the idle, thanx.
As for the fill clutch reservoir, first time i hear about this....will take a look for sure thank you. Will have to do a little research as i don't even know where it is.
Unless you can point me ?
Thx guys.
Marc
Thx guys.
Marc
Received 3,628 Likes
2016 C6 of Year Finalist
You DO have a manual, right? Open the hood and looking into the engine bay it's gonna be one of those little black caps staring back at ya.
it should be right over by the brake fluid reservoir and windshield wiper fluid
Hello all,
i revived the thread to have new ideas about the problem.
I stored the car for the winter yesterday, but befor i did, this is what i did to try to resolve the problem. With the help of others here, i checked the clutch level, all good.
Cleaned the throttle ( was dirty )and the MAF sensor. Mechanic re-initiate the idle also. Was told it could take a couple days or weeks to adjust.
Well it didn't. Actually, it is now far worse than it used to be. The good side of this is that we are probably getting closer to the problem since after what we did, it got worse... Now it's litterally jerking. It was difficult to notice before.
Any new jdeas ? Is changing the MAF sensor something anyone of you did wit this kind of probem
Thx guys.
Marc
Thx guys.
Marc
#34
Hello all,
Thx guys.
Marc
Thx guys.
Marc
#36
Ok
Thx guys. Will try to change the clutch fluid next spring.
Will see from there. But, for sure what i did so far had to do with the problem since it got worse after some work.
Marc
Marc
