Double DIN Head Unit (Stereo) Install Problems
Yes, there is something very special about updating. You need to purchase the "Updater" device for an additional $59.
This is NOT included with the RP5-GM11. Mine works fine, so I will not be updating it.
UPDATE PORT (not USB):
Received 1,636 Likes
Have you tried to re-index the windows. If you disconnected the battery during your install you probably need to index them. Real simple to do, just get in the car and close the door. Close the window all the way. After you have the window closed, use the switch to try and raise the window again but this tie hold it for 3-5 seconds and then let go. They should be reset after that.
will this also work? or should i just go for PAC RP5-GM31 - they are all about the same money
You can use the Crux interface you mentioned if you want a cheaper alternative. The RP5-GM31 is not for a C6 Corvette.
