FORGESTAR WHEELS: Plastic Hub Ring Device ??????
Old 10-04-2018, 12:43 PM
CamarosRus
CF Senior Member
Default FORGESTAR WHEELS: Plastic Hub Ring Device ??????
FORGESTAR WHEEL OWNERS: Are you familiar with the Plastic Hub Ring Centering Device
that came with your Rotary Forged Wheels ????
Are there any negative issues associated with mounting running these Wheels (CF10's)
on my 2012 Grand Sport.
The ForgeStar Web site nor my (ex) selling dealer made any mention of the use of these centering
devices nor that FORGESTAR Wheels are NOT Hub Centric. I became nervous, upset, and wary
and my purchase "BLEW UP"
Ive even had one SoCal FORGESTAR Dealer that they and there customers "Have Never
Used a Hub Ring" ??????
so would ONLY the lug bolts/nuts be centering the wheels ???
Please dont suggest I buy REAL Forged Wheels like ForgeLine or HRE....Im well aware of their
Quality, Beauty AND $$$$$$$$$$$$$
CamarosRus is offline
Old 10-04-2018, 01:12 PM
BadAV
CF Senior Member
BadAV's Avatar
I used hub centric rings on a set of aftermarket wheels on my Avalanche for 10 years without issue.
BadAV is offline
Old 10-04-2018, 01:49 PM
car2fast4you
CF Senior Member
car2fast4you's Avatar
Refer to post #28 in this thread:
https://www.corvetteforum.com/forums...ubcentric.html
Corvette C6 wheels are lug centric.
car2fast4you is offline
Old 10-04-2018, 02:08 PM
jumpmanmb87
CF Senior Member
jumpmanmb87's Avatar
Just use them and stop cryin, been using mine for 2 years and zero issues
jumpmanmb87 is offline
Old 10-04-2018, 02:22 PM
Patriot Six
CF Senior Member
Patriot Six's Avatar
Been using the plastic hubs on my Forgestar F14s for the past 18 months without an issue.
Patriot Six is online now
Old 10-04-2018, 06:08 PM
Ahrmike
CF Senior Member
Hub centric rings help you align rims when you install the rim. Back of napkin calcs seem to say: at 80 ft/lbs, a typical bolt is putting roughly 4K lbs of clamping force per bolt for a total of 20K per rim. with aluminum on steel, thats roughly 10,000 lbs of loading per rim. Even with a F.S. of 2, thats 5,000 lbs per rim that a properly torqued rim will take via friction.
Ahrmike is offline
Old 10-04-2018, 11:38 PM
mkitt27
CF Senior Member
mkitt27's Avatar
Why 2 posts on this same topic ?? See my reply in the other post.
mkitt27 is offline
Old 10-05-2018, 12:15 PM
CamarosRus
CF Senior Member
POST # 28 from the OTHER THREAD
Quote:
Originally Posted by HumanVette
My question is... Are OEM wheels hubcentric. I did a bit of searching on the forum, and I found some posts about it and I believe they are.
Only thing that is throwing me off is, I was talking to some one who sold repro and his exact words were. ''Corvette wheels are not hubcentric. Gm wheelsare also not hubcentric''
So are they or aren't they???
Hello,
I see a lot of back and forth on this question. Just want to clear things up. They are NOT hub centric. The wheels are CENTERED ON THE STUDS and are LUG CENTRIC.
A hub centric wheel is centered upon
installation by the machine fit over the hub, hence the term, the OEM wheels on the ‘Vette are lug-centric, meaning that they are centered by the lugs making it critical that a proper torque sequence, on jack stands, is followed. Not properly following the torque procedure will result in an off center wheel and a vibration concern. Hope this helps.
Geoff Allen
Chevrolet Customer Service
When I took the Corvette Assy Plant Tour in 2005, I SAW the machine
that applied and torques all Five Lug Nuts AT THE SAME TIME!!!!!!!!!
Old 10-06-2018, 12:31 AM
mkitt27
CF Senior Member
mkitt27's Avatar
Torqueing in a criss-cross pattern is important regardless of hub or lug centric. I suppose getting all 5 started gently before significant torque on any would be more important for lug centric. Not sure what jack stands would have to do with anything, other than need the wheel off the ground to get lugs started.
I haven't had my Corvette wheels off yet so haven't seen for myself if hub or lug centric. Never had a car in nearly 40 years of driving that wasn't hub centric. Although the vette is only my second GM vehicle.
mkitt27 is offline
Old 05-29-2019, 07:48 AM
andersnor
CF Senior Member
Im also looking for a 18x11 / 19 x13 setup ideally, seems forgestar only does 19x12 though?
I intend to run michelin cup2 tires, but sadly widest option they have in 18" is 295 30 18
so either 295 30 18 / 325 30 19, or 345 30 19 for rears. both should be fine on 12", allthough 12,5 better.
They do have 19 frotns, but guessing 305 30 19 wont be ideal.
andersnor is offline
Old 05-29-2019, 02:34 PM
myredhead1
CF Senior Member
myredhead1's Avatar
I have had no issues using the plastic rings on my cf10s.
myredhead1 is offline
Old 05-30-2019, 12:14 AM
CamarosRus
CF Senior Member
I wound up buying REAL FORGED Wheels Custom Mfg in TAIWAN (not mainland China)
These are Hub Centric
These are the least expensive FORGED Wheels on the Market and have many
desirable styles and Finishes
Brushed Aluminum Tripe Black Tint
Brushed Alum Blk Tint Left Clear Powder Right
Brushed Alum Bronze Tint
Gloss Blk Powder
Satin Blk Powder
Quick Reply: FORGESTAR WHEELS: Plastic Hub Ring Device ??????
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
