Numbers in marker on inner door??
Old 10-09-2018, 11:20 PM
topgunvette
topgunvette's Avatar
Default Numbers in marker on inner door??
Checked out a car today and noticed on the inner driver door towards the hood, numbers written in what appears to be black marker.
Could this be something from factory?? The car looks clean, no accidents on the carproof either.
Link to pic
https://images.craigslist.org/00p0p_...Nc_600x450.jpg
Old 10-10-2018, 10:19 AM
z06clif
z06clif's Avatar
Could be ....I have numbers wittten at various places on the car....most prominately on the inside fender well in the engine compartment somebody wrote Z06. Dont know why ...probably a assembly line thing. Cant see why the car is a widebody big difference between a Z06 and a base but there it is
Clif
Old 10-10-2018, 10:42 AM
topgunvette
This is just a regular Vert. I heard of them marking in the factory but usually not in visible areas which is why I was wondering about this car
Old 10-11-2018, 09:05 PM
topgunvette
Anyone else confirm having this in a visible spot?
Old 10-11-2018, 09:56 PM
buckmeister2
buckmeister2's Avatar
Received 1,206 Likes on 824 Posts
It might help if we knew what year and body style it is, so we could focus on that. In any case, I have no markings in visible areas, certainly not anywhere on the inner door surface.
Old 10-12-2018, 12:42 AM
owc6
owc6's Avatar
Received 4,186 Likes on 2,679 Posts
I have never noticed any markings in that spot with a marker. Not with all the miles and washings.
Sounds like damage or added aftermarket stuff, somehow).
Marker wouldn't last long, regardless.
A negative carfax means nothing, anyway.
Old 10-12-2018, 01:04 AM
f1reb1rd
f1reb1rd's Avatar
Originally Posted by owc6
i have never noticed any markings in that spot with a marker. Not with all the miles and washings.
that was interesting i have a 2017 and did not find any markings on my doors
Old 10-12-2018, 01:23 AM
owc6
owc6's Avatar
Pics couldn't hurt, either.
Old 10-12-2018, 02:08 AM
topgunvette
It's a 2006 vert. I've linked a pic. It's hard to tell in the pics but it's definitely black marker or something permanent along those lines.
Old 10-12-2018, 06:40 AM
BadAV
BadAV's Avatar
Received 2,674 Likes on 1,699 Posts
If you don't like it or want it there, take a Mr. Clean Magic Eraser and scrub it off.
I worked in tier one OEM part supply for over 20 years and was in assembly plants in the US, Canada, and Mexico on a regular basis. I don't remember ever seeing a mark like that on a finished body panel, unless it was grease pencil marking a paint flaw that was to be corrected.
Old 10-12-2018, 08:28 AM
Welker1
Welker1's Avatar
I have a 2006 and there are no visible 'marker' notations anywhere. That being said, when my Camaro was rear-ended and (after) it was repaired, I noticed a couple of marker notations on the inside of the trunk hood that was repaired. In my case they were yellow, probably due to my car being black, and it was 3 numbers that to this day I have no idea what they indicated. I used a little bit of my wives nail polish remover and got them off.
Old 10-12-2018, 09:15 AM
Corvette_Ed
Corvette_Ed's Avatar
Received 2,843 Likes on 1,801 Posts
Typically when you see writing on a painted surface it's because that part came from a junk yard.
Old 10-12-2018, 09:36 AM
PCMusicGuy
PCMusicGuy's Avatar
Definitely not original. I have seen marks on the back sides of the OEM front bumper, but they were not in black marker.
Old 10-12-2018, 10:17 AM
topgunvette
My main worry is it is not the original door, indicating a accident at some point. It's listed as no accidents.
Old 10-12-2018, 10:20 AM
Corvette_Ed
That's what I was getting at with my post. Odds are likely that your door is not original to the car.
Old 10-12-2018, 10:24 AM
HBsurfer
HBsurfer's Avatar
Received 1,105 Likes on 706 Posts
FYI, as others have noted, a clean Carfax does not mean he car was never in an accident. Carfax only knows about repairs if the person doing the repairs reports it.
Old 10-12-2018, 10:28 AM
topgunvette
To Numbers in marker on inner door??
Old 10-12-2018, 11:16 AM
Racer1735
Racer1735's Avatar
Doesn't have to be an accident, as in a wreck. It could be that they opened the door into a post, or something happened to crease or dent the door, thus calling for its replacement. Anyhow, markers on the inside of a body part generally indicate its not original
Old 10-12-2018, 01:01 PM
buckmeister2
Yellow markings would likely indicate replacement with a used, original part. That is the course of action for most repairs which only require panels, or other bolt-on parts. If you crunch a door, dent a hood, etc., it is much cheaper to replace with an original panel than to do the repair work to the damaged item. And, the repair facility feels much better about warranting an undamaged item than a repaired item.
Old 10-12-2018, 01:21 PM
Welker1
Welker1's Avatar
That's kind of the assumption I came to; it was easier to replace the lid then to try and straighten out the lip that had been bent.
Quick Reply: Numbers in marker on inner door??
