Silly key fob question... I'm a little embarrassed...
Hi all,
Don't shoot me but I tried doing a search on this and came up empty. I lost one of my two key fobs years ago and don't want to get stuck losing my ONLY remaining key fob... Two questions:
1) In order to re-program a new key fob I need to know which key fob I'm dealing with, right (key fob 1 vs 2)? How can I tell which key fob I currently have??
2) My current key fob case is beat up but it works perfectly. Where's the best place to get a suitable replacement case?
Thank you all!
Thank you all!
Your key fob should have a 1 or 2 on the bottom to tell which one it is. It could be rubbed off if its not there. As far as case, I'm not really sure. I would like to know myself. Not sure the cases I have can withstand another battery replacement. I'm sure someone else will chime in.
vara411 (10-19-2018)
It doesn't matter what FOB number you currently have. If your car has memory functions and those memory functions work with your current FOB then you have either FOB #1 or FOB #2 because only those two FOBs work with the memory.
When you buy a replacement FOB you can program it either as an "additional" FOB, will be #3 or #4 depending on how many have already been programmed to the car. OR you can program it as #1 or #2 to work with the car's memory functions. To program as #1 or #2 you have use the "long procedure" which erases all FOBs in the car's computer. Then you program the FOBs in the order you want them to be #1 and #2. The first FOB programmed will be #1, the next one will be #2. You could program the NEW FOB as #1 or #2, doesn't matter, and it doesn't matter what number might be stamped on the FOB case.
You could pay a dealer to do the programming for you or you can do it yourself. It has been suggested a few times here that since the long procedure requires erasing all FOBs currently programmed to the car, it might be a good idea to take the car to a dealer lot to do the programming in case something goes really wrong and you can't complete the process. At least you wouldn't have to pay for a tow to the dealer. AFAIK no one has reported having that problem here but, you know, peace of mind.
FOB programming instructions. Read it thoroughly, you have to follow the directions exactly:
https://www.corvetteforum.com/forums...tructions.html
https://www.corvetteforum.com/forums...-detected.html
Cherokee Nation (10-20-2018)
