Tranny Trouble
Tranny Trouble
my 2007 z51 with 112000 miles started slipping when shifting into 3rd gear. Wondering if anyone else has this happen, and how to fix.
Automatic or manual...….
Yea it'd help knowing which one, alright.
If AT, has fluid been changed?
It's overdue, y'know.
If manual, remember car has 112K so how it been driven?
IMO a new clutch @112K wouldn't be unusual, especially if symptom's slippage.
Received 1,636 Likes
"Tranny Trouble".... you should probably move this to Off-Topic section of the forum.
Jeff T. (10-22-2018)
Good luck!!
Yes ...at 112,000 not at all unlikely to have slippage. Chevy trans are prone to malfunction after 100,000. Some get lucky and have no issues. Changing fluid will sometimes bring issues to the surface.
That crap can/does break loose & often clog things up, then it very likely needs a rebuild.
The expert wrench I use would not flush trans on our high mile Cad for this very reason.
He drained everything he could, refilled rest w/ fresh fluid & the slippage we were experiencing went away.
Trans performed like new 'til we sold it 2 years later.
Consult w/ a reputable trans shop, by reputable I mean solid refs since these outfits have been known to be shady.
Do a search for any Corvette Clubs close by, write an email to the provided addy, ask who their members use for this kind of work.
G/L, keep thread updated.
I know not a Vette, I had an 06 Toyota Camry never has an issue ever , had a transmission service which included a flush in 5k miles started slipping went to the dealer they said the trans needs to be replaced. I went to an independent shop said it happens all the time when they use the flush process. Car had 120k.
Received 1,136 Likes
I'm neutral on the "vert" thing, having never owned one and never expect to.
And I'm fine with "Vette", often using it myself. However, some use "vet" which is sacrilegious and should be forbidden.
