Diy:::: Top and rear hatch partitions
Race Car Tech
::::DIY:::: Top and Rear Hatch Partitions
I am giving forum member jost6453 full credit with coming up with the idea of adding a top partion to the rear partition mod to the interior.
Based on his design, and with his helpful info on building these, I set out to do just that.
The reasons I wanted to do this were threefold:
a) A good way to replace the cargo shade
b) Add the top partition to block off some of the noise coming from the empty space.
c) Stop some of the wind buffeting with the targa top removed on a nice sunny day.
I've attached my DIY in PDF format with pictures and description.
Hopefully, it will inspire others to take on this great interior mod.
The following 5 users liked this post by 4SUMERZ:
BigBlok502 (11-01-2018),
CWIC (11-01-2018),
eckseleven (11-01-2018),
tommygunC6 (02-08-2024),
Welker1 (11-05-2018)
4SUMERZ (11-01-2018)
Race Car Tech
Race Car Tech
Nice work.
But one of the big reasons I bought MY Vette was the large cargo area. I was looking at 370Z's and Porsche Caymans, but they didn't fit my lifestyle as well. I do get some looks when I take my Vette fishing with ice chests, tackle boxes, etc. But it's so much more fun than taking the Cherokee over Hwy 17 to Santa Cruz.
06Rawpower (06-19-2019)
Nice work.
Thank you 4SUMERZ for the shout-out. It is a great little mod for many reasons. And not to worry about limiting cargo space. Both panels just lift right out.
4SUMERZ (11-05-2018)
BTW ... I have provided paper templates of both pieces for a few members that have requested them. Let me know if I can help you out! -DJ.
Race Car Tech
Nice work.
As DJ has mentioned, both are easily removed as needed, and the cargo shade can be re-deployed in those cases where more height space is required for certain trips.
I also looked at many road trip vehicles in the sporty class, and the C6 ticked off all of my needs. Most of the sports cars have limited space for storage (suitcases, golf clubs, etc.
very nice and clean mod. thank for posting.
4SUMERZ (06-25-2019)
4SUMERZ (09-08-2019)
I can provide the templates and guidance, but I do not sell complete. They are time consuming to make and very expensive to ship due to the size.
'Hats off'! to 4sumerz for a great write-up. I'll just add a couple comments ....
I used wood for the divider although I agree foam would work equally well. If you go with wood, use something that will not warp. I used a piece of 6'x 1' laminated pine (edge glued boards). No warp issue. You will need to route in a slot to provide enough room for top storage
For the top panel, you can get by without adding plywood if you use 1" FOIL faced foam. The foil on both faces will prevent sagging. Without plywood added, it remains light enough to fasten with Velcro.
Good luck with this project! I have one in both my C5 and C6 coupes and love them! -DJ
bobeyoung (09-08-2019)
Race Car Tech
It was your design, with your help and guidance that got me to do this for my C6.
Race Car Tech
The attached PDF if expanded will show you the dimensions at various locations of both partitions. You can use these dimensions, transfered to cardboard, then fit and trim to the hatch area until you are satisfied with the fit taking into consideration of the width of the carpeting that will cover the partition.
Good Luck
Good Luck
Good Luck
Good Luck
