Navigation Radio Problem - CorvetteForum - Chevrolet Corvette Forum Discussion
Old 11-18-2018, 08:26 PM
gwhite1950
Junior Member
Default Navigation Radio Problem
I have a 2008 Corvette Convertible
I have a problem. I opened my nav screen to remove the Navigation Disk and put an updated disk in. After ejecting the old disk, the screen closed and now it will not open.
The screen is lit and says: CAUTION CANNOT LOAD SYSTEM SOFTWARE DISK TYPE IS INCORRECT PLEASE INSERT CORRECT SYSTEM DISK. There is no disk in the system and it will not open to let me put the new disk in. Is there a way to get this screen open? HELP
gwhite1950 is offline
Old 11-18-2018, 11:23 PM
4SUMERZ
CF Senior Member
Support Corvetteforum!
4SUMERZ's Avatar
Just one of those electrical glitches that sometimes occurs with the C6 system. You can pull the 15 fuse (RDO/S-BAND/VICS), in the passenger footwell, and it will likely reset the Nav unit and will work again, or disconnect the main battery (but you will have to re-index windows)
I had the opposite happen, I opened the Nav door, and it wouldn't reclose with the push button.
I pulled the 15A fuse, it reset, and it never happened again.
4SUMERZ is offline
Old 11-18-2018, 11:54 PM
gwhite1950
Junior Member
I have tried both those solutions and neither one worked. i am a loss. About ready to get an aftermarket system and put in my vette. Can't seem to find anyone that knows how to get this open. thanks
Old 11-19-2018, 09:37 AM
Kenny94945
CF Senior Member
Kenny94945's Avatar
FWIW One can manually force the door closed, but
I have not tried manually opening (Yes grab with hands
and apply pressure to close).
Just sometimes time will cure it....park over night, retry in the AM.
Disconnect battery...park over night, retry in the AM.
Tap the side of the console and the radio face plate with a rubber hammer.
Apply dry high pressure air around the unit.
All above again just FWIW.
Let us all know if you have success and what worked.
Kenny94945 is offline
Quick Reply: Navigation Radio Problem
Sponsored Ads
Vendor Directory
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
