GM fuel pump letter is a joke BEWARE
#42
Ok so I'm outside the 10 year limit on the fuel pump replacement, Does anybody know a reliable non dealer in South Orange County California that can handle changing a fuel pump on a 2008 automatic?
I usually do all my own repairs but watching on-line video's, it looks like it would be easier on a rack, that you can stand under for better leverage.
The local dealer service adviser had that blank stare, when asked if they had ever done this repair before. Very scary!!
#43
#44
FYI, I can put you into direct contact with the lead NHTSA investigator if you want to contact him. I worked directly with NHTSA for over year on this investigation. The Corvette is only one of many GM models that have had this problem. Attached is the GM bulletin that was later expanded to include the Corvette. There is NOTHING in it that references the electrical connector.
CONDITION
Some 2006 model year Pontiac Pursuit, 2006-2007 model year Saturn ION, 2006-2009 model
year Chevrolet Cobalt, 2007-2009 model year Chevrolet Equinox, Pontiac G5, and Torrent, and
2008-2009 model year Chevrolet Uplander and Pontiac Montana SV6 vehicles may have a
condition in which the plastic supply or return port on the fuel pump module may crack. If either
of these ports develops a crack, fuel will leak from the area. The customer may notice a fuel odor
while the vehicle is being driven or after it is parked. If the crack becomes large enough, fuel may
be observed dripping onto the ground and vehicle performance may be affected.
CONDITION
#45
Received 4,707 Likes
This repair is a MAJOR fix, with a automatic car, basically the whole back end of the car needs to be disassembled to be able to get the room to drop the tanks, most dealers are getting 2k + for this repair
#47
So if you have a basic econo car like the Cobalt your cover for life, ("replace the fuel pump module regardless of the vehicle's age or mileage") but for a high end car like the Corvette or Cadillac you only get 10 years...Really?? I think something is wrong here.. I have a 2008 Vette that only has 20,000 miles on it, and it's not covered because it is out of the 10 year window by 5 months. Plus i never received the warning letter.
#48
Southsling, you are correct, This should be a recall for all C6 model years, its a freakin safety issue
#49
I took my 2013 GS to my local Chevrolet dealer due to the dreaded fuel smell. After checking it out they found it leaking at the pump. Classic scenario between 1/2-3/4 full and raw fuel puddle on top of tank. Should be no contest it fits the letter we all received with the 10year 120 thousand mile coverage for this issue. NOTTTTTT The tech writes it up and in his opinion this doesn't match the bulletin. They then go to the area rep and ask him for assistance and they offer to let me get the repair that is in the bulletin for just $750.00. What a bargain. Then they also told me to call Chevrolet direct for assistance as that usually gets approval. WRONG The customer assistance rep agreed that what I was saying sounded like it was as described in the letter. She then put me on hold and called my local dealer. Comes back on the phone and said the tech wrote it as not fitting the scenario and that I should take the deal they offered as the area rep was doing a good will offer and I should be thankful for that. we had some more conversation and she said I could take it to another dealer for an additional look at it and see what they would write it up for. This has not gone well and I am going to retrieve my car and just drive it and see what happens. Pretty sad when the repair my dealer claims is required is the same fix we are supposed to be getting AT NO COST to us. I will just leave it parked outdoors now as I don't want it in my attached garage. I will keep it below half a tank. Sad to say a 14k mile vehicle has this issue.
someone should write a book on this and title it "unsafe on any day"
89talon (12-10-2018)
#50
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
#51
I took all of your advice and went to a different Chevrolet dealer this morning. They called this afternoon and it is being covered under the GM program and will be ready Tuesday.They had to order the parts. It was exactly what the bulletin showed for cracks in the fuel module. Register Chevrolet in Brooksville, Florida should be ashamed of themselves for asking me to pay for a covered repair. Thank you all for your comments and advice it was your help that kept me focused and out of the car showroom. I really haven't found anything that impresses me enough to drop my 2013 GS.
Also, as one member posted it wouldn't be covered as your case was in the system as a denial, good to see that this wasn't the case.
Will definitely steer clear of Register in Brooksville for any auto needs - you should post online reviews of them where ever possible.
#52
#53
By the way, I'd STRONGLY recommend having the passenger side fuel sending unit replaced now while it is apart. I did not do mine and I really wish I had, because it failed about a year later, and now I'm looking at having to do it all over again.
#54
I'm the same. I'll have to go back through my Corvette correspondence and see if I missed something somewhere. I definitely see this as a major recall issue and wonder why NTSB have not been notified?
#55
Bigredwing (12-09-2018)
#56
WestCoastCorvette (12-10-2018)
#57
I'm glad they got it taken care of. Unfortunately, since Brooksville is a relatively small town there isn't a lot of competition and you don't always get the best employees. It also says a lot about a service manager when he doesn't question his technician basically writing a cause that won't cover a safety condition. Fuel coming from an electrical connector would raise some serious red flags with me....electricity flows through there, not fuel that. It also doesn't make sense when a dealer will lose a warranty repair by being greedy trying to make it customer pay. I work for a dealership in service and parts and we will do whatever we can to get a repair covered by warranty so there is guaranteed payment and to help build a relationship with the customer. Luckily, you're not THAT far away from other Chevrolet dealerships for future needs.
ontime (12-09-2018)
#58
Cool thanks.. I actually lived in Harbor City many moons ago. I will check them out.
I may also check out Corvette Mike's in Orange, little closer to where I live.
Still hoping GM will cover this repair...Even though the car is a little over the 10 year limit.
#60
Received 2,683 Likes
2018 C6 of Year Finalist
Bigredwing (12-10-2018)
