LS2 Spark Plug question
I believe that plug is one step colder than the stock LS2 "110" , the actual spark they produce will be the same but the "104" plug will transfer heat to the head quicker thus the temp of the plug will be cooler, if you have a LS2 with bolt on's and a tune with the timing tables advanced some than that plug will probably run close to what the stock plug ran on a stock LS2. Preignition and detonation and knock sensors trouble are usually set off by a overly heated plug ground strap.
Received 1,136 Likes
There is lots of "funnin" going on in this thread and it has already been visited a couple of times by the CF clown car....LOL....
Imaginations go overboard when it comes to ignition systems and what they actually do. Slick marketing has done its magic convincing the naive to consider all the wrong things. It does sell product so mission accomplished.
The job of an ignition system is to ignite the fuel mixture. There is nothing about the intensity or strength of the spark, or the variance of voltage that improves or degrades combustion of the fuel. When the fuel mixture is ignited, the intensity and speed of the burn, resulting in some given power output has ALL to do with the properties of the fuel and nothing to do with how it was set on fire. Whether you ignite with a match or a blowtorch, the fuel will burn with the same intensity and time.
The focus should be on degradation of the ignition system over time. How long does it take the various parts of the ignition "chain" to wear out to the point that spark to ignite the fuel at the tip of the plug becomes intermittent or permanently missing.
In an LS design (which is 100 years old), ignition originates at the coil and the chain includes a coil wire (with 2 connector ends) and a spark plug. Many much more modern systems shorten that ignition chain by placing the coil directly onto the spark plug eliminating 3 possible failure points. But back to working with what we have on an LS3. if the coil is good, the wire and connections are good, and the spark plug is good....A spark is a spark. It'll get the job done without spending a fortune in boutique aftermarket parts.
1) On previously-mentioned 327 Camaro, I installed a C1 Corvette dual point distributor I bought from a friend. I never took it to the strip, but it made zero difference on the street.
2) I had a '74 900cc Kawasaki motorcycle with points ignition. Even if the points were a bit crappy or out of adjustment it still ran fine, no skips even at the 9,000 RPM redline.
3) I had an '88 Harley Softail with electronic ignition. It was only two years old and it crapped out, had to get it flatbedded home. I bought an aftermarket electronic ignition but could never get it adjusted right so I took it back. I did a little investigating and found I could convert it to points for about ten bucks, plus the cost of the points and condenser (maybe another ten bucks. They were 6-cylinder Chevy points). The part of the engine casting that the ignition went into hadn't changed in decades and it was a simple screw-in job.
It started better, hot or cold, than it did with the electronic ignition. A buddy of mine had ridden it quite a bit and commented on how much better it ran than his Harley did. I carried an extra set of points and condenser with me, but never needed them in the 25 years I ran it with points. I sold it in 2015 to a guy I know, still runs great, guy loves it.
So to boil it all down, what Blindspot said is pretty much true: ignition is ignition. The precision of today's ignition systems was likely driven by Washington mandates for ever-increasing emissions and mileage standards -- not that the engine runs noticeably better or puts out more noticeable power.
Attachment 48333445
my money is going with the original plugs & wires.
I've had my '09 for almost two years now ( 98k miles when I got it ).
I just replaced the plugs & wires @ 138k miles. as far as I could tell, these were the original pieces.
I only replaced them since I felt it was time. this mileage & performance were both doing great.
one plug was missing the entire electrode. the remaining ones were mostly close to the stock gap.
a couple of the wires were dry rotted and broke upon removal.
I replaced with original delco 41-110 units & stock wires.
my car is totally stock & if these last another 100+ miles, I won't complain a bit.
Supporting Vendor
Likewise, if you street drive and don't spend much time at WOT, you will want something different than a drag race only car running methanol, which would want something different than a road race car.
My experience is only with C5's, so take that as you will, but the Brisk Racing plugs that jaredtxrx mentioned (thanks for the shoutout) are what I consider the best for a road racing application. I have customers that run them on the street and have not reported any issues, but as I mentioned above, everyone's definition of good/better/best is different. I had plenty of success running traditional plugs before I switched to the Brisk ones.
So about the Brisk plugs mentioned, they are classified as surface-fire spark plugs. Similar to the electrodeless plugs you'll see in racing, these plugs are designed to run the spark across the nose insulation before arcing across an air gap to the electrode (or outer ring of the plug in the racing versions). The electrical resistance to an arc running along the surface of an insulator is less than that of going through a compressed air-gas mixture for the same distance. Because of that, a larger total gap (insulator and air) can be designed into a surface fire style plug. The end result is a larger spark, and therefore a larger initial flame kernel than with a traditional plug. Think of it as igniting three times the initial number of fuel and oxygen molecules as a traditional plug.
There are some other benefits like better cold starting and a more exposed spark/flame kernel that negates the need to index the plugs.
Overall though, these advantages are on the level of serious race teams only, specifically teams that are in limited prep classes. For something like SCCA autocross in Street classes where you can only change plugs and a cat back, and championships are won by thousandths of a second, this sort of thing makes a difference. The example from my testing (back to back, new standard plugs to new Brisk plugs) was 7 HP and 9 ft-lbs (you can see the results on the site here or in my BS Build Thread on the forum). That's great for a plug change, but it's also only about 2.1% and 2.8% rear wheel gains respectively To some people (like me and my race/track cars) that matters. To anyone asking me about their street car, I would say spend your money on other things. Some of that gain would be negated by being able to tune your car (which we did not do for the test, it was the stock GM LS1 tune), but not all. If you aren't restricted by race rules, you would likely be looking at 1-2% total gains that you would be unlikely to feel.
Since it sounds like you don't have a specific ruleset for your car, I think a number of the plugs mentioned would be fine. If you do have a specific race build you're working on (or just want to know more about the science behind these plugs), just let me know and I'd be happy to help. Hope that helps
__________________
Borg Motorsports
www.borgmotorsports.com
Lane Borg - Owner
lane@borgmotorsports.com
2012 AS Solo National Champion
2014 BS ProSolo and Solo National Champion
Borg Motorsports
Lane Borg - Owner
the irony of the funnin' here is that there is correlated science behind my question which is supported by dyno proven fact, not just marketing. the granetelli wires are between 0.01 and 0.00 ohm which means money well spent for someone with a mother ******* am radio transmitter for the iphone. thats significantly less interference. the stock wires are like .2000. not only that but if you know anything about how a lighting rod works and electrical conductivity, then one would know that a wire using less ohms would be more efficient in supplying the flow of energy to the plugs. less resistance in the type of wire material they use. if you do some research yourself you would find that multiple dyno shops including my own tune time performance can agree with the plug and wires. my prior c6 on the dyno when i had it tuned was having issues related to the spark plugs with there most aggressive tune and they highly recommended the tune up. with this being said. on said vet with just the new plugs and wires, i have no clue what they put in last time. was ******* 20rwhp. i went from 340 to the 360 after a damn tune up and retune. idk about this marketing thing lol...tune time is pretty reputable....
I CALL B.S. You TROLL.... Me I'm sticking with OEM.
I'm lost... In your op your not sure about plugs you purchased took back and then asked us what should I do? Concenses say stick with stock. So you bash us for our input and sarcastic comments only to now do a 180 and shout from the roof top that you have stat data and now a tune, saying Dyno time proves all.
What a complete waste of time! My posts deleted and done with this guy.
Tens of thousands of ohms resistance in the spark gap and 1 or 2 ohms of plug wire resistance is going to make a difference? You know the secondary winding of the ignition coil has a lot more resistance than that don't you? The difference is 99.999% of the coil energy is delivered to the gap vs 99.99%.
To the OP:
Two heat range colder plugs are designed for engines 150-200 more HP, whether the engine is N/A or S/C. A colder plug transfers heat faster from the tip to the combustion chamber, keeping the plug tip cooler. This helps prevent detonation because higher performance engines can produce higher combustion chamber temps. Running a plug too cold for and engine can cause the plug to foul out.
In your case, with only and intake, it is best to stay in the stock heat range, whatever plug you prefer. I would recommend the stock AC plugs and wires.
The NGK Iridium are good plugs and I run them, but I am boosted.
Keep the stock gap! Your application has no reason to change heat range or spark plug gap. One reason boosted engines run tighter gaps is to prevent spark blow out.
As far a spark plug wires, I run the oem wires (750 ohms) and they are just fine.
#33
Received 3,066 Likes
2021 C6 of the Year Finalist - Modified
That's just silly !
I'm going with the proven big power adder ... The 'Electric Supercharger' !
Even has a 'High Flow' K&N style air filter ...
_____________________________________
Chevy Corvette Electric Supercharger Kits Chevy Corvette Supercharger
When people see you rolling in a Chevy Corvette they expect you to have only the highest quality parts installed. Thanks to our shop you can have those parts, specifically a Corvette supercharger, which will give you an instant kick in torque and overall performance, without having to break the bank. You can roll in style knowing that you didn’t have spend an arm and leg to get the best Corvette super chargers and Corvette turbo kits on the market. At our shop we pride ourselves on offering only the best Corvette super charger kits at the lowest prices, so you save. Get your Chevy Corvette super charger from us today and feel the difference for yourself. You won’t be disappointed once you open that throttle and feel the kick of your need, powerful Corvette supercharger.
http://www.superchargerswarehouse.co...Superchargers/
#35
That's just silly !
#36
Received 2,060 Likes
yes TUrbo, they are original and this car sat outside and saw no love for a long time. the wires are a tel tale sign. i just got my garage cleaned out and shoved her in there. also it wasnt mine when it sat out i just bought her. has about 60k. but as i read in an earlier post and dont quote me if i am wrong but changing your plugs every 100k is like saying ill change my oil every 10k. you could but its not the best thing. also i just did and intake and it need an oil change so im there why not? also doing a new balancer. yay.. old one ripped right off
Best of luck to you with that low mileage babied LS2, if it doesn't eat your wallet first.
BTW, leave the potty mouth at home if you want to stay in the good graces of the moderators here.
#37
That's just silly !
#38
Ouch !
#39
Internet tough guys rule!!
