seat belt - CorvetteForum - Chevrolet Corvette Forum Discussion
seat belt
Old 12-05-2018, 07:55 PM
yellow2007
CF Senior Member
yellow2007's Avatar
Default seat belt
My drivers side seat belt has been acting up lately. It doesn't make that familiar "click" when inserted. it's a little harder to get in but it does fasten and it does release. I've tried wd40, lithium grease but don't want to gum up the mechanism. I've seen them online but wanted to ask if anybody hs changed theirs and did it involve removing the seat.
Thanks in advance.....
yellow2007 is offline
Old 12-06-2018, 09:48 AM
Kenny94945
CF Senior Member
Kenny94945's Avatar
Look for a button, paper clip, coin, debris that fell into the assembly.
Flash light, dental tools, let gravity help do the removal work for you in
an obstruction is found.
Yes to change, best to remove the seat.
There is electrical wiring to the seat belt assembly.
Top tip, place a heavy blanket over the still panel to avoid a scratch from the seat
upon removal.
Kenny94945 is offline
Old 12-06-2018, 10:15 AM
JABCAT
CF Senior Member
JABCAT's Avatar
I just recently removed my seatbelts & had them re-webbed with custom webbing. You do have to at least lift up the seat (not remove completely). (4) 15mm nuts hold the seat to the floor. Check out Safety Restore if you need your belts repaired.
JABCAT is offline
Old 12-06-2018, 07:40 PM
yellow2007
CF Senior Member
yellow2007's Avatar
Thank you both. I'll try the debris thing first. That makes sense. If not then I'll pick up a replacement and install......
Old 12-06-2018, 09:54 PM
MrDoll05C6
CF Member
I suggest using a graphite lube. It will last much longer than WD-40 and will not gunk up the mechanism.
MrDoll05C6 is offline
Old 12-07-2018, 07:35 PM
yellow2007
CF Senior Member
yellow2007's Avatar
Thanks. Will try that
Old 12-08-2018, 04:58 AM
Scott Tenold
Junior Member
Where can you buy the seat belt replacement? Just bought the car and has coin stuck in it!! Thanks Scott
Scott Tenold is offline
Old 12-08-2018, 09:32 AM
JABCAT
CF Senior Member
JABCAT's Avatar
Check out Safety Restore. Send them your belts & they have 24-hour turn around.
JABCAT is offline
Sponsored Ads
Vendor Directory
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
