2012 GS Max Rear Tire Width
Looking to potentially go a little wider out back. What tire sizes have people put out back on their Grand Sports with the stock 19" wheels?
Currently have 325/30/19's on the rear.
Pictures would help as well if someone has gone to 335 or 345 on the 19" rears.
Also, did it throw off your speedo or any other issues?
I had 345s on my 2010. If you get the correct size fronts ro match, it's not an issue. That said, they're expensive, and didnt really add any extra grip compared to a 325, you get a better grip increase from tire compound than tire width.
GingerGranny (01-08-2019)
I have been looking into this for a while anticipating my next tire purchase. Based on what I have found on this forum it's hit or miss whether or not there are issues with the traction control system utilizing the stock front tire size.. Going to a slightly larger tire size in the front will fix any issue, its the ratio between the front and rear tire, something around 1.1:1 is optimum. There is a lot of info in this subject on the forum.
The issue I have found is finding a matching set utilizing 285/18 on the front and 345/19 on the rear. It seems that these are not popular sizes Michelin and Nitto seem to be the only ones I can find, and they are not cheap. It adds an extra $500-$1000 to the set depending on the mfg. Post up if you find another option.
If you go to a 19/20 wheel size there seem to be more tire options. I personally don't like the look of a 20 wheel on the rear of a C6, I think the 19 with a fatter tire wall fills the wheel well much nicer.
I have 345's on the back. I've seen threads where people ran 355's. Tire Rack had a closeout sale one time on the 355's and people used them. Here's some links.
https://www.corvetteforum.com/forums...5-30-19-a.html
https://www.corvetteforum.com/forums...-zo6-rims.html
https://www.corvetteforum.com/forums...r-z-or-gs.html
The issue I have found is finding a matching set utilizing 285/18 on the front and 245/19 on the rear. It seems that these are not popular sizes Michelin and Nitto seem to be the only ones I can find, and they are not cheap. It adds an extra $500-$1000 to the set depending on the mfg. Post up if you find another option.
I'm running 345's on the back and stock size on the front. I'm even mixing run flats on the front and non-run flats on the rear. I haven't had any issues.
The rear tires on my 2011 Grand Sport are the stock size and everytime I look at them from the rear, I cannot get over how freaking wide they are. I don't think going any wider would make any difference in grip.
The following 2 users liked this post by Spaceme1117:
GingerGranny (01-09-2019),
sam-garcia (10-09-2022)
I'm one of those. 285 pirellis on the front and 355 on the back. Got the backs for about $125 each. They rode nice, were pretty grippy, lasted a lot of miles, and looked great too. Boy oh boy would I love that deal again!!
Anyhow, 355's will fit.
I got a similar deal for PSS in a 345/30/20 for $380 shipped a pair. Not quite as cheap but definitely cheap for a PSS
I have purchased Michelin Super Sport 345/30-19 & 295/30-19 from DiscountTireDirect.com (20% rebates during BlackFridayWeekend) (Free Shipping NO Sales Tax)
I have also ordered SIGNATURE SV501's in 19x12.5 et57 & 19x10.5 et37 Brushed Finish with CLEAR Powder Coat Finish
I also purchased these at Black Friday pricing (contact Khoa@SignatureWheels.com)
I will post pictures when I have received wheels, mounted, balanced and installed
I didn't go wider on the tires, but added spacers to fill out the fenders better. 1/2" hubcentric spacers front and rear. But that necessitated longer studs which ended up being a lot of work. Oh well .... that's behind me now and it looks great. Might be a good option if you are more interested in 'look' vs grip.
Received 1,636 Likes
I prefer 20s personally. I ran a higher sidewall than what's popular and it completely filled out the wheel well without needing to lower the car at all. I like some meat on my sidewall and 19s just didn't fill out the rear well enough for me. This is 285 30 19 fronts and 345 30 20 rears.
