10mm (~3/8") Wheel Spacers Seller Question
Old 01-10-2019, 08:02 PM
nbhansfo
nbhansfo's Avatar
Default 10mm (~3/8") Wheel Spacers Seller Question
I found this set by a high rated seller. They claim that they are hubcentric corvette offset spacers and look legitimate. Would it be okay to go with these and then find a vendor that sells the 3.25" Wheel Hub Studs? I just find it ridiculous that the couple vendors that sell the spacer plates (3/8 and 1/4" are just thin CNC plates usually) are about $130 on sale for a 2x set. T6-6061 CNC'd Aluminum is not that expensive. I used to do some machining so I'm a bit confused on the pricing for basic spacer plates.
Listing Link:
https://www.ebay.com/itm/4X-10mm-Hub...:pf:0&LH_BIN=1
Quick Reply: 10mm (~3/8") Wheel Spacers Seller Question
