Fuel pump fuse
Received 1,116 Likes
These should be your underhood fuses. You are not very specific
No.
Device
Rating
Description
1
TCM/TRANS (MYC)
10A
Automatic Transmission and Transmission Control Module (TCM)
2
HORN/ALT SENSE Fuse
15A
Generator and HORN Relay 34
3
ABS/MRRTD Fuse
10A
Electronic Brake Control Module (EBCM) and Electronic Suspension Control (ESC) Module
4
WIPER Fuse
30A
WIPER ON/OFF Relay 45 and WIPER RUN/ACC Relay 42
5
STOP/B/U/LAMPS Fuse
15A
Body Control Module (BCM) STOP LAMP Relay
6
02 SEN Fuse
15A
Heated Oxygen Sensors (HO2S)
7
BATT5 Fuse
30A
Body Control Module (BCM) TELE SW/MEM SEAT MOD, DRIV DR SW, IGN SW/INTR SENS, ONSTAR, and TPA Fuses
8
PK LAMPS Fuse
10A
PARK LAMP Relay 37
9
PT INPUT/ETC Fuse
10A
Engine Control Module (ECM)
10
MAN TRAN SOL Fuse
10A
Skip Shift Solenoid (MM6/MZ6 w/JL5)
11
ECM/TCM/EASY KEY
15A
Engine Control Module (ECM), Remote Control Door Lock Receiver (RCDLR), and Transmission Control Module (TCM) (MYC)
12
ODD INJ Fuse
20A
Odd Fuel Injectors and Ignition Coil/Modules
13
MRRTD Fuse
25A
Evaporative Emission (EVAP) Canister Vent Solenoid and Electronic Suspension Control (ESC) Module
14
EMISSION Fuse
15A
Evaporative Emission (EVAP) Canister Purge Solenoid
15
A/C COMP Fuse
10A
A/C COMP Relay 35
16
EVEN INJ Fuse
20A
Even Fuel Injectors and Ignition Coil/Modules
17
W/S WASH Fuse
15A
W/S WASH Relay 36
18
HDLP WASH Fuse
20A
HDLP WASH Relay 46
19
RT LO BM Fuse
20A
Right Headlamp Ballast
20
FUEL PUMP Fuse
20A
FUEL PUMP Relay 55
21
LT LO BM Fuse
20A
Left Headlamp Ballast
22
FRT FOG LP Fuse
15A
FOG LP Relay 38
23
RT HI BM Fuse
10A
Right High Beam Headlamp
24
LT HI BM Fuse
10A
Left High Beam Headlamp
25
COOLFAN
60A
Fan Control Module
26
BATT3 Fuse
60A
Body Control Module (BCM) A.C. LATCH/PK BRK B, BTSI SOL/COL LOCK, CLUSTER, DOOR LOCKS, HVAC/PWR SND, INTERIOR LIGHTS, PWR FLDG MIR-EXT/RET, RADIO/ANT/VICS, REAR FOG/ALDL TOP SW Fuses, and RUN/CRANK Relay 2
27
ABS Fuse
60A
28
HVAC Fuse
40A
Blower Motor Control Processor
29
BATT2 Fuse
40A
Folding Top Module and REAR DEFOG Relay 4
30
STARTER Fuse
40A
CRANK Relay 43
31
AMP Fuse
30A
Audio Amplifier
32
Empty
Not Used
33
BATT1 Fuse
60A
I/P Fuse Block DOOR CONTROLS and POWER SEATS Circuit Breakers, HEATED SEAT LH, HEATED SEAT RH, and POWER LUMBAR LH/RH Fuses
34
HORN Relay
Horns
35
A/C COMP Relay
A/C Compressor Clutch
36
W/S WASH Relay
Windshield Washer Fluid Pump
37
PARK/POS LAMP Relay
Park Lamps
38
FRT FOG LP Relay
Front Fog Lamps
39
HIGH BEAM Relay
High Beam Headlamps
40
REAR DEFOG Relay
Rear Window Defogger
41
WIPER HI/LO Relay
Wiper/Washer System
42
WIPER RUN/ACC Relay
Wiper/Washer System
43
CRANK Relay
Starter
44
POWERTRAIN IGN1 Relay
EMISSION, EVEN INJ, ETC, FUEL, O2, and ODD INJ Fuses and A/C COMP Relay 35
45
WIPER ON/OFF Relay
Wiper/Washer System
46
HDLP WASH Relay
Headlamp Washer Fluid Pump
47
LOW BEAM Relay
Low Beam Headlamps
48
SPARE FUSE
10A
Not Used
49
SPARE FUSE
15A
Not Used
50
SPARE FUSE
20A
Not Used
51
SPARE FUSE
25A
Not Used
52
SPARE FUSE
30A
Not Used
53
Empty
Not Used
54
FUSE PULLER
Fuse Puller
55
FUEL PUMP Relay
Fuel Pump and Sender Assembly
F5
DIODE 2
Wiper/Washer System
F16
WIPER Diode
Wiper/Washer System
F19
DIODE 1
Wiper/Washer System
No.
Device
Rating
Description
1
TCM/TRANS (MYC)
10A
2
HORN/ALT SENSE Fuse
15A
3
ABS/MRRTD Fuse
10A
4
WIPER Fuse
30A
5
STOP/B/U/LAMPS Fuse
15A
6
02 SEN Fuse
15A
7
BATT5 Fuse
30A
8
PK LAMPS Fuse
10A
PARK LAMP Relay 37
9
PT INPUT/ETC Fuse
10A
10
MAN TRAN SOL Fuse
10A
11
ECM/TCM/EASY KEY
15A
12
ODD INJ Fuse
20A
13
MRRTD Fuse
25A
14
EMISSION Fuse
15A
15
A/C COMP Fuse
10A
A/C COMP Relay 35
16
EVEN INJ Fuse
20A
17
W/S WASH Fuse
15A
W/S WASH Relay 36
18
HDLP WASH Fuse
20A
HDLP WASH Relay 46
19
RT LO BM Fuse
20A
20
FUEL PUMP Fuse
20A
FUEL PUMP Relay 55
21
LT LO BM Fuse
20A
22
FRT FOG LP Fuse
15A
FOG LP Relay 38
23
RT HI BM Fuse
10A
24
LT HI BM Fuse
10A
25
COOLFAN
60A
Fan Control Module
26
BATT3 Fuse
60A
27
ABS Fuse
60A
28
HVAC Fuse
40A
29
BATT2 Fuse
40A
30
STARTER Fuse
40A
CRANK Relay 43
31
AMP Fuse
30A
Audio Amplifier
32
Empty
Not Used
33
BATT1 Fuse
60A
34
HORN Relay
Horns
35
A/C COMP Relay
36
W/S WASH Relay
37
PARK/POS LAMP Relay
Park Lamps
38
FRT FOG LP Relay
Front Fog Lamps
39
HIGH BEAM Relay
High Beam Headlamps
40
REAR DEFOG Relay
41
WIPER HI/LO Relay
Wiper/Washer System
42
WIPER RUN/ACC Relay
Wiper/Washer System
43
CRANK Relay
Starter
44
45
WIPER ON/OFF Relay
Wiper/Washer System
46
HDLP WASH Relay
47
LOW BEAM Relay
Low Beam Headlamps
48
SPARE FUSE
10A
Not Used
49
SPARE FUSE
15A
Not Used
50
SPARE FUSE
20A
Not Used
51
SPARE FUSE
25A
Not Used
52
SPARE FUSE
30A
Not Used
53
Empty
Not Used
54
FUSE PULLER
Fuse Puller
55
FUEL PUMP Relay
F5
DIODE 2
Wiper/Washer System
F16
WIPER Diode
Wiper/Washer System
F19
DIODE 1
Wiper/Washer System
No worries, and often its not the fuel pump fuse the problem, but the fuel pump relay and it pathways/relay clip points in the fuse box the problem isntead.
So the easy way to test the fuel pump pressure and wiring, is to just jump it out at the fuel pump relay point to start with. This bypasses the relay and ECM command to energize the relay to start with.
Also comes in handy if you need to drain the tanks through the fuel rail schrader valve on the driver front side under the fuel rail cover as well.
