Intermittent Air Bag Light
My 05 has it too. There is a blue or yellow wire plug behind middle of drivers seat it may be loose or coming loose. When seat gets adjusted back and forth say from a tall driver to a short driver it tends to come loose from the movement. Locate plug and push back together and then use a wire tie to hold it together.
94Green (01-15-2019)
Received 4,712 Likes
What Mlcharlstonsc said,The problem is most likely the plug coming loose under the drivers seat & is a "common" problem with C6 Corvettes
Simple first check - check connector under seat - push together and use a cable tie to apply added pressure ... do this for both the driver and passenger seat if the light stays on - I personally had a passenger seat connector issue on my 2008 base.
94Green (01-16-2019)
