New stereo with front and rear cameras installed
Old 01-31-2019, 04:05 PM
  #41
Canuckster
Junior Member
I'm assembling all the parts to do pretty much the same thing with my new Pioneer HU. Thanks for all the helpful info and photos.
The one thing that puzzles me is:
While the rear camera is only turned on when in reverse does that mean the front camera is on continually while the ignition is on?
It appears to be that way in the Pyle instructions so it must be OK but I still wonder.
Any thoughts?
Canuckster is offline
Old 01-31-2019, 04:15 PM
  #42
TorchRedFred
CF Senior Member
TorchRedFred's Avatar
Any thoughts?
Most of the time the front camera is wired to be continuously on when the car is on. Shouldn't be an issue.
TorchRedFred is offline
Old 01-31-2019, 09:09 PM
  #43
mcandrew67
CF Senior Member
mcandrew67's Avatar
2016 Corvette of Year
2015 C6 of Year Finalist
Any thoughts?
I would assume so, just make sure you wire the power to a switched circuit that goes off with the ignition, I believe the power
Outlet in the center console stays on
mcandrew67 is offline
Old 02-01-2019, 02:22 PM
  #44
RogerRamjet21
CF Senior Member
RogerRamjet21's Avatar
Originally Posted by mcandrew67 View Post
I used body molding mounting tape to put it under the lip to the left of the rear keyhole. I will look at the model # of the Cameras when I get home and post up. My wife purchased them for me, will ask where she ordered from.
Same for the front the auto body molding mounting tape, in the center under the lip of the opening in front of the egg crate grill. It has a bracket that you can screw to the body, I chose the tape route, I have used it in the past and it sticks great. Just need to make sure you clean really well with alcohol. I fished the wire through the grill, I put it inside the high temp split loom in pic below, it protects the wires.
What size split loom? Looks like 1/4 inch would work, but not sure...
RogerRamjet21 is offline
Old 02-01-2019, 07:06 PM
  #45
mcandrew67
CF Senior Member
mcandrew67's Avatar
think I had about 3/4 as i have the av connectors inside too. I also taped the connectors together. Also only took it in that up to the door.
Old 02-02-2019, 07:00 AM
  #46
NDMIKE88
CF Senior Member
NDMIKE88's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Great job on the install..very neat and professional looking.
NDMIKE88 is offline
The Following User Says Thank You to NDMIKE88 For This Useful Post:
mcandrew67 (02-02-2019)
Quick Reply: New stereo with front and rear cameras installed
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
