2007 brake reservoir
Doing some much needed maintenance on my newly purchased c6 and I’m having a problem finding a new brake fluid reservoir. Mine has been neglected over the years and Is badly stained. I cannot find a replacement does anyone have any ideas where I can buy one. Don’t want to buy a new master cylinder. I also read where if you remove the reservoir it will throw a code and a tech 2 will be needed to clear.
Have you tried a local company that rebuilds master cylinders? I don’t know about setting a code, wouldn’t disconnecting the car battery prevent this?
Careful with paint and brake fluid.
No idea why brake battery is blue or and and underlined, I try to edit the colors and it links to eBay
