Broke the tab on injector electrical connector. What now?
Old 02-10-2019, 09:48 PM
Bigwebb
Bigwebb's Avatar
Default Broke the tab on injector electrical connector. What now?
So I was swapping my intake manifold and one of the tabs on one of the injector connectors broke off. It will push down onto the injector still, but it doesn’t lock into place. A couple of questions. First, can I rig it to secure it temporarily so that I can drive it to a shop? Second, if I want to fix it myself, how would I go about that? Just chop the wire and splice another one on there and electrical tape it? Does it need to be soldered?
Thanks in advance for any advice.
Old 02-10-2019, 09:59 PM
Turbo6TA
Turbo6TA's Avatar
Received 3,087 Likes on 2,078 Posts
2021 C6 of the Year Finalist - Modified
Push the connectors together ... Then a couple of drops of 'hot-glue' from one of those hot glue guns between the wire connector and the injector ... fixed
Old 02-10-2019, 10:14 PM
Bruze
Bruze's Avatar
Received 1,136 Likes on 882 Posts
. . . or, another option that I've used successfully for vibration (on an electrical connection on a machine tool): Squeeze some silicone on the assembled joint and let it set.
Old 02-10-2019, 10:20 PM
Tuna Goat
Tuna Goat's Avatar
I broke one when installing my fast intake.. Zip tied it to the injector.. Hasnt moved and I daily it ..
Bigwebb (02-11-2019)
Old 02-10-2019, 10:35 PM
Bruze
Bruze's Avatar
LOL, how did we ever survive before they invented zip ties?
Old 02-10-2019, 10:56 PM
Tuna Goat
Tuna Goat's Avatar
It was hit and miss for a while there but then they came out with multi color zip ties and ohhh baby ....... not like that harness has any kinda pressure load and you cant see it so .......
Old 02-10-2019, 11:08 PM
Turbo6TA
Turbo6TA's Avatar
'Chicken Wire' ...
Old 02-10-2019, 11:14 PM
Bruze
Bruze's Avatar
'Chicken Wire' ...
Yes! And electrical tape.
When I was a kid I was always raiding my mom's Scotch Tape and grocery string supplies. It got so bad my sisters made a joke about it -- which they still remember.
Old 02-10-2019, 11:25 PM
BackInBlack05
BackInBlack05's Avatar
I believe the pins can be poked out and a new housing installed. It takes some special tools though.
Old 02-10-2019, 11:41 PM
rjacobs
rjacobs's Avatar
They are available for like 3 bucks.
Ev6, ev14, uscar are all names for the connector.
Lots of options. Google if your friend.
Hell I think I have a few in the tool box... But if you broke one, you'll break more. Buy extra.
Old 02-11-2019, 03:05 AM
BackInBlack05
So these I presume:
Amazon Amazon
Old 02-11-2019, 08:24 AM
z06clif
z06clif's Avatar
Plastic tie wrap
Clif
Old 02-11-2019, 11:22 AM
rjacobs
rjacobs's Avatar
Originally Posted by BackInBlack05
I wouldnt cut wiring...
I got mine from this place.
https://www.bmotorsports.com/shop/in...58hnvg8tbp99o0
Old 02-11-2019, 11:39 AM
BackInBlack05
So a new housing as I suggested above? Procedure for replacing housing?
Old 02-11-2019, 11:58 AM
Bigwebb
Bigwebb's Avatar
Thanks man! This is a relief. So just a zip tie, tight around the outer shell of the connector and letter rip?
Old 02-11-2019, 05:03 PM
jackjohnson_218
jackjohnson_218's Avatar
Gorilla tape!
Old 02-11-2019, 05:08 PM
saplumr
Support Corvetteforum!
saplumr's Avatar
Received 1,251 Likes on 895 Posts
The old reliable rubber band.
To Broke the tab on injector electrical connector. What now?
Old 02-11-2019, 05:32 PM
cmonkey713
cmonkey713's Avatar
Received 1,251 Likes on 916 Posts
A drop of RTV silicone works prefect.
Old 02-11-2019, 08:04 PM
rjacobs
rjacobs's Avatar
you get in and release the pins. They make tools to do it. Its not that hard. Then they just slide into the new connector.
Old 02-11-2019, 08:06 PM
rjacobs
rjacobs's Avatar
I dont get all the suggestions to rig the injector connectors up when replacements are readily available and $4 and take about 5 minutes to swap.
Ever seen what happens to a motor when it leans out due to an injector stopping firing? It aint pretty.
Quick Reply: Broke the tab on injector electrical connector. What now?
