Wiring gurus, I need help with a switch
I want to know how I should go about wiring up a switch to my mild to wild.
I recently purchased a latching style push button switch and would like for it to control the mild to wild I have installed.
It has an orange LED ring built in and I want it to light up when LOUD(valves open) and turn off when valves are closed(QUIET/mild). It has a red and black wire(+ -) for the LED, two white, and two green wires. The instructions say that it’s made for 5A but anything more than 3A draw continuously needs a relay.
so how do I hook this up using a relay as well as using the mild to wild box/hook ups? The mild to wild has a fob that controls “on” or “off”. I do not want this. I want the new switch to be the only control. I’ll attach pics below of the switch and the instructions and the mild to wild.
mild to wild has a black wire(ground), blue wire(antennae for fob), red and white are together coming from the box to the exhaust fuse in the passenger side panel.
Thanks in advance
Brenton
Thanks in advance
Brenton
[QUOTE=heavychevy357;1599029893]In short I want to know
Since a previous post answered your question... Never say "in short" when you are talking about wiring!
[QUOTE=Bob Paris;1599030128]
My company had to hire an electrician to hook up a lathe that we purchased and when the electrician showed up in a panel van with huge graphics showing a lightning bolt and "Jack Short Electric" I asked him if he ever gets given a bad time about his choice of a company name.
I didn't use a mild to wild box or a light up switch for mine. I got a plain old rocker switch and hid it in the console. I tapped into the fuse panel with an add a circuit that had an inline fuse running to the switch and then back to the add a circuit. Used a 10 amp fuse because that's what gm has. I think that I got a normally on but I can't remember exactly, it's been a couple of years. Anyhow, I do remember that flipping the switch off completes the circuit and it's quiet. flip the switch the on breaks the circuit and it gets loud. er. ish. It still isn't really loud.
Which opens my second question. What to do with the extra wires? I know the LED wires but two for NO and two for NC. Do I just use two NO as one(twisted together) and two NC as one?
5th Gear
For want you want a mild to wild is just a complication. I went to billetautomotivebuttons.com web site. that switch is only rated for 5 amps and the fuse for the npp is I think 10 amps. That switch is too light for your application you could use it but it may not last for long. I would recommend doing what Sox-Fan has done if you can live without a lighted switch. There are some good writeups from people who have already done this. If you really want to use your billetautomotivebuttons switch you will need a relay. Your switch would operate the relay and the relays contacts would switch power to the npp circuit. Wiring for this might best be handled by you local performance shop.
I know but I I’m not sure where to land the extra wires I need. I have 6 in total. Seems like way to many. Maybe I should do away with the mild to wild altogether and wire in the switch as the sole function.
Just make sure the switch and relay both have the correct contact rating.
Forget the indicator light thing. Grab a footswitch high-low beam switch with the pigtail connector and put it in your dead pedal. Wire it into the fuse location as an on/off switch, done. Just like H/L beams of old.
It looks like you want to do something similar to what I did, my switch lights up when the NPP valves are closed and quiet. You have a single throw/double pole switch so you will only be using one set of NC/NO contacts, the other set will not be used, unless you want the LED to have its own set of contacts. I don't have a mild to wild, I just added a pneumatic solenoid inline of the vacuum hose going to the NPP valves, it closes off the vacuum line when I want it loud, and opens the line when I want it quiet. Check out my YouTube video:
[QUOTE=BigBlok502;1599052012]It looks like you want to do something similar to what I did, my switch lights up when the NPP valves are closed and quiet. You have a single throw/double pole switch so you will only be using one set of NC/NO contacts, the other set will not be used, unless you want the LED to have its own set of contacts. I don't have a mild to wild, I just added a pneumatic solenoid inline of the vacuum hose going to the NPP valves, it closes off the vacuum line when I want it loud, and opens the line when I want it quiet. Check out my YouTube video:
Exactly. Thank you Big Block. I want it to light up when loud so I’ll wire it accordingly. I’ll do away with the M2W altogether. I have a relay rated for 30A I’ll be using so to those of you who mentioned that I have it covered. Thanks guys!!
