More newbie questions
Sorry but I learn a lot here. 1st question is what is everyone using for there manuel clutch fluid in the resesvor? Second question is it was showing my left rear tire low, so I added air but it still hasn't changed tire pressure and shoes low? I hope a sensor isn't bad. Any ideas?
I believe the fluid to use DOT 4 brake fluid ( double check though ).
are all of your other sensors working correctly?
longshot, but when I had new front tires installed, the shop reversed the TPM sensors.
when I got the low pressure warning, I filled up that tire, no change though.
after a few times, I happened to notice the other tires pressure was changing.
otherwise, your sensor may be losing its battery and is not reading at all.
45gunner (03-14-2019)
Received 1,781 Likes
cgladish (03-13-2019)
as above, it might not be the tire that you think it is that's low. Also with Corvettes simply putting air in it will not turn out the light. You have to drive it a little bit for the sensor to read. with some cars you jsut need to air them up. with a corvette you have to air it up and then the tire with the sensor has to rotate.
Be sure and keep the clutch fluid clean. It WILL extend the life of the clutch. There is a good write up on the forum by Ranger. It is DOT 4.
Do you have a good tire pressure gauge to check the pressure with? TPMS are good to alert you to a problem but not as exact as a good gauge and checking manually.
carl3989 (03-14-2019)
I'm just reporting what happened. I had a battery operated pump with me, and a pressure gauge, so I just pumped it up, and drove about 1/2 mile to a tire shop, where it was repaired. I wasn't paying any particular attention to the DIC, but it seems to me that when I started the car after pumping the tire back up, I didn't get any low pressure warning. This was back in July,, but I'm still sure that I got the low pressure warning without moving the car right when I started it the first time. This was when I had the green TPMS sensors, if that matters.
Thanks everyone again. Did the fluid change per Ranger method and it was the other tire sensor. Must have gotten swamped with tire change. So all is good now. Thanks again for all the help.
