Ambient temp outside
Old 03-23-2019, 02:25 AM
Mets231
Mets231's Avatar
Default Ambient temp outside
My 05 corvette reads 75 degrees at all times in the cabin. I found the wire but it is not connected. I cannot find where it plugs into. I have attached pics. Thank you
Old 03-23-2019, 08:59 AM
4SUMERZ
Race Car Tech
Support Corvetteforum!
4SUMERZ's Avatar
Received 2,320 Likes on 1,664 Posts
The AT module is found on the right side and lower part of the radiator.
Here is a pic of it's location.
It can be accessed from the engine bay.
Old 03-23-2019, 03:54 PM
Mets231
Mets231's Avatar
Thank you for the pictures.
I am still unable to see where it will connect.
I had the shroud replaced and cut out to accommodate for the air intake, and I think where it connects to was removed.
Old 03-23-2019, 05:07 PM
4SUMERZ
Race Car Tech
4SUMERZ's Avatar
Is the Air temp sensor even there physically? You should be able to see it if it's there. It's not hard to see if you look down the side of the radiator, as per the pic.
This is what the sensor looks like.
Old 03-23-2019, 05:11 PM
Mets231
Mets231's Avatar
Nope. It is long gone
Old 03-23-2019, 11:22 PM
4SUMERZ
Race Car Tech
4SUMERZ's Avatar
They are inexpensive to replace, Rock Auto, any forum vendor will have these readily available. The sensor just fits in the slot, and is held on the frame with a push fastener.
Good luck
To Ambient temp outside
Quick Reply: Ambient temp outside
