Polish / Clay - what next?
Old 04-05-2019, 04:33 AM
Gixxerman
CF Senior Member
Gixxerman's Avatar
Liked 39 Times in 34 Posts
Originally Posted by stingray71 View Post
Did you try the plastic baggie test?
The Plastic Baggie Test: If you put your hand in a sandwich bag (or on top of a piece of cellophane) and lightly glide your hand across the surface, youíll be able to feel every last imperfection. Youíll feel bumps not visible to the human eye, and these are, in fact, telling you itís time to clay. The test should take any longer than five minutes and can be done during the clay process to make sure no areas were missed.
Gixxerman is offline
Old 04-05-2019, 04:37 AM
Gixxerman
CF Senior Member
Gixxerman's Avatar
Once you get it smooth I would probably use Griot's Garage correcting cream on an orange pad. Waxes and Polishes are subjective everyone has their favorites, just remember a clay bar will strip off treatments you have used, you pretty much strip everything off down to the finish so you need to start over say maybe color corrections, polish, sealer then a ceramic coat if you want.
The following users liked this post: Gixxerman
Mayor111 (04-06-2019)
Old 04-06-2019, 11:10 AM
Not So Fast
CF Senior Member
Not So Fast's Avatar
Liked 847 Times in 638 Posts
I threw my Clay Bars away a long time ago when I discovered the NanoSkin Auto Scrub sponge, they come in 2 different grades to suit your needs, Ive never used any but the Fine blue one and it is amazing and so easy to use. One thing is you use a lot of lubricant with them, either the Glide they have of some other detail spray other wise they will drag on the surface.
If your car isn't to bad you can do the entire car in about 1/2 hour with ease, then wax it with your choice and it will be slicker that a piece of glass, which BTW I use it on the glass also
NSF
Not So Fast is offline
Old 04-13-2019, 12:04 PM
ls1121
CF Senior Member
Support Corvetteforum!
ls1121's Avatar
Liked 73 Times in 63 Posts
St. Jude Donor '14-'15
Originally Posted by ruxvette View Post
Henry ford poured alcohol on a fender and set it on fire. Perhaps you should try that...
When you do this please take some pictures of the process, I would suggest that you start with the seats first, make a video please.
ls1121 is offline
The following users liked this post: ls1121
jimijam (04-13-2019)
Old 04-13-2019, 01:34 PM
jimijam
CF Senior Member
jimijam's Avatar
Liked 110 Times in 90 Posts
jimijam is offline
Old 04-13-2019, 08:08 PM
Jstan2014
CF Senior Member
Jstan2014's Avatar
Liked 254 Times in 221 Posts
Jstan2014 is online now
Old 04-13-2019, 08:27 PM
ssg10587
CF Member
ssg10587's Avatar
Liked 12 Times in 9 Posts
Did this today with my DD. Clay -> 205 -> 105 -> fusso coat. Feels like glass. Do you have any deep scratches there? Maybe go with 105 then wax and see then?
EDIT: Nvm looks like you solved it. For clay I used mothers speed clay 2.0. I've never seen the point of claying with a DA. Easy to juet wet the car and speed clay it. Think I do the whole car in maybe 5 minutes.
ssg10587 is online now
Old 04-14-2019, 10:43 AM
windyC6
CF Senior Member
Liked 393 Times in 339 Posts
HUH ?? Help an old dude out. What is "speed claying" ? I would assume that you mean that you clay the entire car in just 5 minutes ?.......
windyC6 is offline
Old 04-14-2019, 11:37 AM
ssg10587
CF Member
ssg10587's Avatar
Amazon Amazon
Would recommend, its awesome and yes I do the whole clay process in about 5 mintues.
Old 04-14-2019, 11:54 AM
cmonkey713
CF Senior Member
cmonkey713's Avatar
Liked 396 Times in 354 Posts
Originally Posted by Don-Vette View Post
Nobody does clay bar anymore, get some Nanoskin!! Its 100 times better!!
Not so fast Grasshopper, many of us use clay and I can tell no difference between the clay and Nonoskin. The nano may be a little faster but the end result is basically the same.
cmonkey713 is online now
Old 04-14-2019, 11:59 AM
Not So Fast
CF Senior Member
I am an OLD DUDE and I have been using the NanoSkin Fine Grade Sponge on all my cars for sometime now, for reference I threw my clay bars away, no comparison IMHO. 1 hint is to use plenty of lubricant spray as you do it, any detail spray will suffice.
and if you drop it of it gets dirty just wash it off with cold water unlike clay that you would have to throw away. You should YouTube them. Good luck
NSF
https://www.amazon.com/s?k=nanoskin+sponge&i=automotive&ref=nb_sb_noss_1 https://www.amazon.com/s?k=nanoskin+sponge&i=automotive&ref=nb_sb_noss_1
Old 04-14-2019, 04:29 PM
windyC6
CF Senior Member
This is what I find fascinating.....(and I know the forum members that use it are gonna have a cow....LOL). But so we rub a piece of clay over the car to pick up dirt and grime....etc....etc. Then this dirt and grime stick to the clay and will still be in the clay when we are rubbing it all over the rest of the car. And as one post suggest, if you drop this clay on the ground then you are hosed cause you just got a lot more dirt in the clay so you shouldn't use it. Wouldn't surprise me that if in about 20 years all the car "Experts" are gonna be saying....."Can you believe that 20 years ago people would actually rub clay all over their cars thinking they were taking care of the paint when actually all they were doing is rubbing dirt from the paint all over itself"........
windyC6 is offline
Old 04-14-2019, 04:36 PM
  #33
449er
CF Senior Member
449er's Avatar
Liked 293 Times in 249 Posts
That's a great tip, And I thought that I new everything about car detailing! Lol
449er is offline
Old 04-14-2019, 04:37 PM
  #34
Chance575
CF Senior Member
Liked 1 Time in 1 Post
I’ve found naanoskin doesn’t work so well on heavily contaminated paint. On mild stuff it’s great, I still break out the clay for the heavy work .
Chance575 is offline
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
