Battery Charger on a LS-7
Received 4,713 Likes
Can you charge/maintain a battery through the cigarette lighter on a dry sump trunk mounted battery? Thanks
Received 1,596 Likes
Cigar lighter works great for a battery tender, but as stated above, NOT to CHARGE a battery. A tender will put out .7 to 3 amps which is safe for a car's electrical wiring.
Battery chargers should be connected directly to the battery, with the battery cables disconnected so as not to damage the BCM. (Disconnect the negative terminal first.)
Whenever I use a battery tender, I always use the lowest setting. That is easiest on the battery. It takes longer, so I plan ahead.
M...
M...
M...
M...
