C6 2005 Corvette driver door won't open from inside
Hi guys as the title says my 2005 won't open unless I use the manual latch on the floor when I hit the release button I just hear a click coming from the passenger side any suggestions ?
Update on the case guys ... Problem solved it was the door latch that was getting locked sometimes.....after using the silicon spray into the door latch everything is working fine just letting Corvette gang know what can be your issue always try every single fix before to buy a part
