Belt noise
Just an FYI, original GM balancers, like you'd likely get as a replacement, have been know to fail.... There are reports on this forum of that happening. Some, not all that long after replacement!
Others have had good results with both Powerbond and ATI. Be aware of potential problems if you use an underdrive (smaller) balancer on a basically stock motor. Some have had charging issues and possible cooling issues.
It seems to be common for a balancer replacement at an independent shop to run about $900. That's for an ATI balancer, belts, bolt, and seal.
Others have done it themselves and saved a ton of $$, but it's more work than I was comfortable with. Don't feel bad, my 2007 had balancer issue a week after I got it.
Good luck.
Good luck.
corvettejoe2006 (04-23-2019)
Thanks for your reply. If it is replaced under warranty, I’ll be okay with the GM part, but will definitely look at the others you and people have suggested if it’s going to cost me anything.
Good luck
Another Update....the Chevy dealer that diagnosed my HB says their Corvette tech guy is leaving for good on Friday.....so I have to bring it to another nearby Chevy dealer with a good Vette tech to get it fixed. Good part is, my small dealer that I bought the car from is going to pay for the fix! I may be getting a GM part, but at least it won't be coming out of my pocket.
“Goes through the hood” is my biggest concern (other than the embarrassment of being stranded roadside as people drive by seeing the pristine convertible with the hood up). Mine didn’t chirp a bit during the test drive or on the 80 mile ride home....and started the next time we took the car out, the next day.
Even if you have to purchase one and give it to them to install, that would be better and give you the piece of mind knowing that you wont have an issue in the future....
You can purchase the - PowerBond Race Series Harmonic Balancer PB1117SS for ~ $225 at O'reily's or many other places......then the ARP bolt can be had on Amazon or Ebay for ~$40.
Good Luck but don't let them put an OEM HB back on you engine!!!
[QUOTE=BMF_C6;1599284325]I would almost have to demand that the GM dealer install an aftermarket HB, the GM HBs are a known issue and what happens a year from now when/if this happens again with no warranty?
When the dealer says they will pay for the whole thing, you are not demanding anything. It's take it or walk and pay for it out of pocket.
GM dealer will install aftermarket parts if you supply them. That’s what I did but of course they would only guarantee their
labor, not the parts. As for being a know issue they always claim “never heard of that problem” . Been down that road many times with both cars and motorcycles .
