C6 auto shifter problems
I have a 2006 c6 shifter would not go into park, reverse on down no problem. I replaced the shifter assembly and the same thing is happening, but if I raise the assembly off the mounting bolts or raise it out of the housing it works fine. Any ideas?
Race Car Tech
Hummmmmmm. Try tying back the locking pawl, then put the shifter back down on the holding bolts and try it again. If it shifts, then it's the Micro-switch which releases the locking pawl that is bad, or if it still won;'t shift, then it's the cable /adjuster on the cable at the transmission end.
Good Luck
Good Luck
You may have snapped the plastic cable guide. I know this because that is what happened to mine when I tried to change the bushing. So I purchased a new cable and replaced it and it works great now.
