Brand new to me...do I have an issue already??
So i just picked up my first C6 Grand Sport on Wednesday last week. Drove it for 1,100 miles and no issues. Idilling and on the highway I am at 40-60 PSI for oil pressure. Let the car sit in the garage for a day. Yesterday I go to take it out and it's literally pinned at 80 PSI when I start it. Stays like that for a good 10-15 minutes and then runs between 45-60 PSI even when at a red light. I push it on the highway a little and still creeps to 80. How did this happened with no issues after an 1,100 drive? Can this be a major issue?
Thanks so much!
Thanks so much!
I have to agree. The oil pressure sensor is going south on you. Good news is it's not a hard fix, and one that you can do yourself if you have any mechanical skills. Just make sure you get the brass sensor to replace the stock one, which you can get from your local O'Reilly's. These forums have plenty of do-it-yourself videos on how to fix it. I fixed the one on my C5 (same as the C6) using a coat hanger.
SPSandman (05-31-2019)
Is this a manual or an auto tranny?
I agree with the others!
Not that this is any revalents to your issue but, where did you pick it up and where are you located? We need some pictures!!
Received 2,885 Likes
Oil pressure sensor failure is pretty common as they approach 10 years.
The sensor is located behind the intake plenum on the drivers side. With small hands and some luck you can swap it out.
I removed the wipers, and windshield cowl then cut a hole in the fiberglass cowl support right above the sensor. You will need a special thin wall socket for the sensor, auto stores have them for around $5. Unplug the connector and swap the sensor then reconnect the plug. I used aluminum duct tape to cover the hole but that is not necessary as it can't be seen after the cowl is replaced.
Amazon has a heavy duty solid brass sensor at a good price (half what my local stores wanted).
Good luck.
Good luck.
That pressure sounds about right for a GS with a manual transmission. The dry sump systems display that kind of oil pressure when cold started. When warm, a normal 40+ PSI is correct. I would not worry about it.
The following 2 users liked this post by arobber:
corvettecolin (05-28-2019),
rc51racer (05-29-2019)
the dry sump oiling system is like that. mine is always 80psi when first started then down to about 40ish when at idle.
there is even a rev limiter in the PCM code for the dry sump if the oil temperature is not above a set amount
Check to see if you have the dry dump oiling system. If you have the mn6 AND magnetic ride your car should have dry dump and it is designed to run at much higher oil pressure. 60-80 psi is normal when cold. Warm idle is approx 40 but will go much higher with increased rpm
Received 1,596 Likes
To the OP, if you do have the dry sump system the procedure for checking the oil level is different than normal. The oil must be up to operating temp (this can take a while with these cars) and then shut off the engine for ~5-10 minutes, then check the level.
This is warm idle:
This is halfway warm and it is still at 60psi:
Thanks so much!
Thanks so much!
Thanks so much!
Thanks so much!
My 2011 Grand Sport manual does the exact same thing. About 65 PSI right when I start it, and pegged out at 80 PSI until it reaches operating temp. Then at idle it reads about 35 to 40 PSI.
I would imagine is is a result of the dry sump engines having two oil pumps, one pushing and one pulling. But I look at this a being an excellent thing.
h8snow (05-28-2019)
Obvious question, but your oil is warmed up right? Your oil pressure will be high with cold oil, and with the dry sump and immense cooling, it takes a lot to get the oil up to temps...
EDIT: The others beat me to it.
