Chart of how many cars were made like yours?
Hey Guys,
Im trying to determine how many 2012 C6's were built with my exact setup, color, options etc. I know I've seen charts that show year over year how many Vettes are made with x & y options, colors, etc.
Can someone please post where that can be found? I searched the sticky's but nothing was there...
Thanks!
Thanks!
Mayor111 (08-19-2019)
Data for that was only kept for two years. You need to interpolate to figure it out.
My CE was 1 of 175 base coupes. One of 20 that came with chrome wheels. With the A6, clear top, and battery protection package it could very likely be a 1 of 1. It no way to prove it.
Race Car Tech
There is a site that will do that for you, but really not sure how accurate it is, because as mentioned, it is interpolated from GM data.
I have a 2006 Velocity Yellow Coupe A6 with 3LT but with the Transparent top only. Many came with both tops, so that alone makes it rare as per the RPO stats, as does the color, as there were only 1540 coupes built that year with VY.
I'm sure that Museum delivery makes it rare in itself because of that RPO code. It is all relative, and it really doesn't matter much.
Here is what my car showed when I did it on that site.
Found 16,598 vehicles matching your year and model in our database.
There are 2 2006 CORVETTE 2 DR vehicles (0.012%) matching your exact options list. There are 10 (0.060%) with at least as many options. My car is really common, why does this indicate that it's rare? If you parked your car next to one of the hundreds or thousands of similar cars in our database you probably couldn't tell them apart, but that doesn't mean they aren't different. For example, some may have an RPO listing for the plant in which they were built. If yours was one of only a few that came out of that plant with a given list of options, it would come back as rare. Another car may have all the same options but was built at a different facility and thusly it's considered different. To check any combination of RPO codes to find how rare your vehicle is based on the most important codes, click here or make changes to the selection above. Getting RPO codes We're digging very deep and this may take MINUTES, not moments. Please be patient. 223 RPO codes offered, checking ALL.
The site, if interested is compnine.com. I believe that you get one free entry. It used to be unlimited free access when it first appeared on the net.
compnine is a good site but you need to make sure you interpret the data correctly.
It will tell you how many cars were made with your exact same RPO codes, but take that with a grain of salt because some RPO codes are regional or odd on other ways and it can make it look like your car is rare when it is not.
I've seen guys with fairly common cars have compnine list their car as 1 of 1 for no special reason at all. It's just RPO code trickery.
I was able to use compnine to determine a Camaro I have is one of 4 convertibles made with a M6 and green gray paint. Pretty cool to know, but nobody gives a crap about Camaros so it doesn't really mean anything.
As others have said you have to interpolate....this one is printable has multiple c6 years...
2012 Corvette Production Numbers Corvette Action Center
