Passenger seat airbag light
Anyone ever had the problem where the airbag warning light on the dash intermittently goes on/off when someone is sitting in the passenger seat? When it’s on, I ask the passenger to shift their weight a little, which results in the light going off for a little while.
I believe the simple fix for this is to make sure the two halves of the electrical connector under the seat are fully seated and then reinforce with a cable tie so it doesn't work itself loose again.
It happens to me once and awhile 2011 GS
ditto on the recall...they repaired it on my 2012. however, it has returned, so i will get it done again next time it goes in for something. i almost never have a passenger in the seat...
Condition can be caused by: "When the seat is moved forward or back, the connector may be dragged along the carpet, pulling terminals loose or pulling the connector apart. This will cause a diagnostic trouble code to be set and the service airbag light will be illuminated."
tdog11 (08-26-2019)
