mechanic coolant and brake fluid price
hey guys called up my local mechanic for brake fluid flush and coolant change. he quoted me 75 for each so 150 for both. i didnt mention dexcool on the phone but il mention once i bring the car. is that price reasonable?
very reasonable honest price.
Retired & lovin' it!
I do these services myself (as do many here) so can't give you any actual costs, but Pep Boys in NJ lists coolant drain & fill starting at $65 and full flush & fill starting at $95. Brake fluid flush with other brake service is listed as $50, but alone would be more. Based upon those numbers, the quote you got seems reasonable. HOWEVER, is your mechanic Corvette knowledgeable? The coolant flush is somewhat difficult on Vettes because it takes a while to totally drain the system (including the surge tank) & then refill requires the system to be "burped" in order to get a full fill. Similarly, the brake fluid flush & refill requires special care with the ABS system. If you're confident that he's "Corvette knowledgeable" then these seem to be good prices. Out of curiosity, what year is your Vette & what's the mileage that's leading you to do these services? Also, if you're having the brake fluid flushed, what about pad replacement?
Received 4,712 Likes
That's a very reasonable price for sure
Received 1,116 Likes
Both of those services have 2 different methods, so might verify why you are getting vs. what you are wanting. Trying not to repeat Dave's post but is it a coolant drain and fill or is it a full flush with a machine?
And is it a standard brake bleed or a brake flush that involves energizing the ABS pumps to get out the fluid that is in them?
Reasonable price, but as mentioned above may not be an annually retentive Vett service.
Brakes...Simple job, remove wheels, attached pressure bleeder tool at master, bleed.
2 (maybe 4) pints fluid.
Otherwise a Tech ii tool is needed to open abs system.
Coolant...simple job drain at radiator and refill.
Or drain at rad. bring up to operating temp multiple times until clear water is present.
Remove coolant tank and clean out with chipped ice.
2 gallons dex cool and distilled water.
Remove air bubbles from system.
Nothing wrong with simple job if the car is regularly maintained.
Have fun!
Have fun!
Really that works!!!!! I've tried everything to get the scum off the inside of my tank. I've got to try this. Thanks for the post.
To the OP: Kenney94945 is correct, all of this is fairly easy, do your homework, then give it a try and the forum will give you great tips like this.
Great price including labor, so long as he has test tool to cycle the ABS pump to get that old fluid out of it during the brake power breed process to get all new fluid into the system.
But since the Dexcool should be flushed every 5 year and replaced, and the brake fluid year (or at least every two years), better to learn how to do it yourself to save huge bank in the long run instead.
