outside temp display
Old Oct 22, 2019 | 04:28 PM
b09676's Avatar
b09676
Default outside temp display
Hi everyone, haven't posted for a long time but here goes - just noticed that the outside temp display not working seems to be frozen at one temp. any ideas?
Old Oct 22, 2019 | 04:30 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
unplug it, clean the connector and plug it back in that fixes it 99% of the time
Old Oct 22, 2019 | 04:49 PM
b09676's Avatar
b09676
where is the plug?
Old Oct 22, 2019 | 05:09 PM
pewter99's Avatar
pewter99
by radiator....right front (passenger side)
Old Oct 22, 2019 | 05:18 PM
Vette_DD's Avatar
Vette_DD
Don't forget that there are some restrictions about when that display will be the same as the outside air temperature.
Read page 8-5 in the owner's manual:
There is also a sensor located
behind the front bumper. This
sensor reads the outside air
temperature and helps to maintain
the temperature inside the vehicle.
Any cover on the front of the vehicle
could give a false reading in the
temperature.
If the outside temperature goes up,
the displayed temperature will not
change until:
. The vehicle's speed is above
19 km/h (12 mph) for
five minutes.
52 km/h (32 mph) for two and
one‐half minutes.
These delays prevent false
readings. If the temperature goes
down, the outside temperature
will be shown when you start the
vehicle. If it has been turned off
for less than three hours, the
temperature will be recalled from the
previous vehicle operation.
Old Oct 23, 2019 | 10:22 AM
irok's Avatar
irok
Press front and rear defrost along with fan speed up or down buttons,all 3 at same time.Correct temp will now update instantly
Old Oct 23, 2019 | 12:10 PM
b09676's Avatar
b09676
Thank you guys. Strangely enough this morning it's back to normal but I have printed out your posts to keep in case I have it reoccur. BTW I also appreciate your knowledge as well as the always quick responses I've had on this forum - you all are the best!
Old Oct 23, 2019 | 01:30 PM
Vette_DD's Avatar
Vette_DD
You're welcome. I had 5 different C6s and for some strange reason, I have an electronic copy of all 9 C6 model years of owner's manuals. Sure makes looking things up a whole lot easier than trying to use printed manuals.
Old Oct 23, 2019 | 08:22 PM
b09676's Avatar
b09676
does the sensor by the radiator,which controls outside temp display, also control the interior dash lights? when my temp display isn't working I noticed there is a lengthy delay before the dash lites come on. Does this make sense and is it all related to the sensor / plug earlier mentioned? Or is that sensor only for an outside temp ?
To outside temp display
