Morimoto XB C7 Style LED Headlights for 2005-2013 C6 Corvette
Platinum Supporting Vendor
https://www.pfyc.com/morimoto-xb-c7-...-corvette.htmlUpgrade from your boring C6 headlights with these Morimoto XB C7 Style LED Headlights for 2005-2013 C6 Corvette.
NO SUBSTITUTES: Yeah the projector headlights that came on the C6 Vette's were modern back in 2005, but by today's standards - their light output is dated and it's hard to argue the modern appeal of the C7's full LED setup! Thankfully the new XB LED headlights: Look great. Are well-built. Have a virtually infinite life span. An unbeatable warranty, and out-perform the alternatives. They are the first and last aftermarket option that the C6 Corvette Community needs, because when it comes to headlights: there is nowhere else to upgrade from here.
PERFORMANCE: We've always been blown away by the fact that even though the C6 came from the factory with OEM HID headlights, the performance was sub-par. The low quality optics inside the lights were not only poorly designed to begin with, but often lose 50% or more of their intensity over time due to de-lamination of the reflector bowl inside - leaving you with next to no light output to illuminate the road. The good news is that Morimoto's 2005-2013 Corvette headlights produce a well defined beam pattern with a great amount of width, intensity, and a proper distribution of light that will far out-perform even the C7's more modern setup.
DOT APPROVED: Make no mistake, these will produce a much different [better] result than slapping some LED replacement bulbs into your stock housings. Their projector optics meet & exceed all SAE, DOT, and FMVSS108 regulations when aimed properly...and that's easy to do with their integrated vertical/lateral adjusters.
PLUG-N-PLAY: Wiring is easy too! This LED projector headlight kit is designed to work on your C6 Vette without any modifications. They will plug into the factory connectors for the stock headlights and each assembly includes all necessary connectors, rubber seals, and pigtails for a plug n play install. No error codes, no flickering, hyper-flashing, or radio interference. They can easily be removed, and will not void your factory warranty.
SEQUENTIAL LED DRL: Game Changer! Their LED daytime running light is powered by Osram 5000K LEDs and is insanely bright, easily visible during the day. They have a fully sequential LED turn signal behind modern "3D" type optics on the outside edge of the headlight too.
WELL-BUILT: Their UV-coated polycarbonate lens will resist the test of time, ensuring your Vette's new headlights will look good as new for many years to come. The PPS plastic housing is light-weight and much stronger than comparable alternatives. The die-cast aluminum heat-sinks inside the housings provide more than an adequate amount of cooling for the OEM grade Osram LED chips that produce the light. These complete headlights may be new to the market, but Morimoto's XB LED fog lights have proven themselves perfect after 5+ years out now, which is confidence inspiring.
THEY LOOK: Amazing. At least in our opinion! The subtle elements incorporated in their design are more than enough to make them stand out, but they're clean enough to be considered top of the line original equipment to those who don't know any better. All in all, styling that closely resembles the C7 headlights - making these the best way to facelift your C6.
TRUSTED: For more than a decade, we've worked hard to earn our killer reputation. Car guys world-wide know that TRS carries the internet's best selection of high performance automotive and powersport lighting products at the best prices, and we've got the best, most knowledgeable team of real enthusiasts to help back it up. If we sell it, then you bet we've put it to the test on our own cars, trucks, and bikes.
Application
•••••- 2005 2006 2007 2008 2009 2010 2011 2012 2013 C6 Corvette
__________________
PFYC.COM - Proudly Serving You For Over 20 Years! Call Us Toll Free: 866.695.PFYC (7392)
www.pfyc.com info@pfyc.com .."we're here to help"
How much are they?
Application
__________________
Old 02-01-2021, 06:00 AM
PFYC
PFYC's Avatar
__________________
PFYC
PFYC's Avatar
Application
__________________
lobstah24 (04-14-2022)
Application
__________________
RE Vette (05-15-2023)
