Camber question
Old Mar 10, 2020 | 06:48 PM
Matthew Awdish's Avatar
Matthew Awdish
Default Camber question
. L
Old Mar 10, 2020 | 06:57 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
Leave the camber alone .... Get the camber out of spec and you will wear out either the inner or outer edges of your tires fast.
Too much negative camber, you wear the inside edge of the tires
Too much positive camber, and you wear out the outer edge of the tires.
Old Mar 10, 2020 | 07:02 PM
Turbo6TA's Avatar
Turbo6TA
BTW ... A 9.5" wheel is too narrow for a 305/45 -17" tire.
I also have MT ET Street S/S drag radials in the 305/45 -17" size on the rear of my supercharged GS ... They are mounted on 17 x 11 wheels, which would be correct for that tire.
Attachment 48333851
Old Mar 10, 2020 | 08:04 PM
Matthew Awdish
so I should just leave it and accept the fact that they rub
Matthew Awdish
ive seen others on the forums with a 305 radial on a 9.5, I know it may seem like a bad idea but they have been working great and hopefully they stay that way - beautiful grand sport btw
edit - I’ve actually seen someone put a 325 on an 8 inch wide rim, that’s just not right imo, your not putting all the rubber to the ground at that point
Old Mar 10, 2020 | 09:11 PM
Turbo6TA's Avatar
Turbo6TA
I also have a 17 x 9.5 wheel on the front of my car ... but it has a 285/40 -17" tire mounted on it (which is the correct size tire for this 9.9" wide wheel.
Old Mar 10, 2020 | 09:17 PM
FAUEE's Avatar
FAUEE
Get a stiffer rear spring, and crank up the height of the rear springs.
Old Mar 10, 2020 | 09:31 PM
Turbo6TA's Avatar
Turbo6TA
I think he first needs to get the correct sized wheel for that size rear tire he is using ...
A 9.5" wide rear wheel is just too narrow for a 305/45 -17" drag radial ... simple fact
Old Mar 10, 2020 | 10:07 PM
FAUEE's Avatar
FAUEE
But but but, he said it's working great, and didn't start a thread about how his tire was rubbing. It's not like pinching the tire on too narrow a wheel is causing it it stick up further...
Oh wait...
Old Mar 10, 2020 | 11:47 PM
Turbo6TA's Avatar
Turbo6TA
The OP has a problem with a tire rubbing somewhere in his wheel well ... but he also has a problem with too wide of a tire mounted on too narrow of a wheel.
Old Mar 11, 2020 | 12:26 PM
Matthew Awdish
L,.
Old Mar 11, 2020 | 02:06 PM
Turbo6TA's Avatar
Turbo6TA
Matthew ....
Do what you want, it's your car
All I was saying is a 9.5" wide wheel is not the correct size for a 305/45 -17" tire
Old Mar 11, 2020 | 03:35 PM
Matthew Awdish
Matthew ....
I didn’t mean to come off in like a harsh way if I did. I was just wondering cause everyone says a 9.5 is too small which I know it’s pretty small for a 305 but it’s only 14 millimeters difference from a 10 inch, does it make that big of a difference?
Old Mar 12, 2020 | 10:11 PM
irok's Avatar
irok
Turbo6TA-the 9 1/2" rim is not too narrow for the MT 305/45x17.It is the narrowest wheel recommended by MT for that tire.It is the rim size I use for the 305/45 x 17 to run those 1.30"s 60ft's with.He already has the right width wheel for the car and needs to raise the jack bolts a little
Old Mar 12, 2020 | 11:27 PM
Turbo6TA's Avatar
Turbo6TA
Okie Dokie ...
Old Mar 15, 2020 | 07:59 AM
irok's Avatar
irok
Matte if you can't adjust the ride height with your jack bolts yourself take it to a shop and have them do it for you before you damage those tires.Its less than 1 hour labor to save those $700. tires
To Camber question
