Early npp
2nd Gear
Early npp
I own a 2012 grand sport, my exhaust gets louder when I start up a hill, I can downshift and it will quiet down,,found the solenoid by the pass side tail light,,all looks good there,,has anybody got any ideas?
Received 1,679 Likes
Try posting in the C6 section...and welcome to the CF!
Moderator
Received 3,622 Likes
CF Banner Relay Captain
West MI & JAX/NE Florida
Events Coordinator
St. Jude Donor '11-'12-'13-'14-'15-'16-'17, '21
I own a 2012 GS with NPP as well. Maybe I'm not following your question as what you describe sounds like what the NPP is designed to do - RPM's go up, exhaust opens and it gets louder. I would think downshifting, though, would increase the RPM's even more causing the NPP to open up possibly.
Received 1,783 Likes
Here is the design: the valves will open at 2,800 rpm above 80% throttle. Between 30% and 80% throttle the exhaust will open during acceleration at and above 3,500 rpm. Mind you, engine load increases going up a hill, so the exhaust will sound louder, especially if you are lugging the engine.
Received 2,061 Likes
The vacuum that keeps the muffler valves closed is reduced during heavier engine loads. So when you downshift, which increases the engine speed to decrease the lugging load, then the vacuum will increase and close the valves again. This is completely normal operation.
Just a little confused by the comment that a 2012 is an "early NPP."
wideglideleon (04-02-2020)
Received 1,675 Likes
I don't quite understand your early NPP reference. I have a 2010 Grand Sport and it has NPP.
