Another door pad cleaning
Driver's side door pad has always been a bit finicky. I'd seen plenty of posts about cleaning but had just never gotten a 'rountuit'. Gave her a quick wash yesterday to clear of the winter grime & decided to clean the pad while I was out there. Easiest fix I've done (well, maybe except for just a reboot with the negative battery cable).
10 minutes tops start to finish. Works great
Received 4,504 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
You can buy a new set off e-bay free shipping no taxes for $24.00, why bother, the seals are probably dried out, and lett moisture getting inside.
Fair point I was planning on doing that one of these days but hadn't gotten my rountuit for that either and I have LOTS of time these days so decided to tackle it.
Received 2,093 Likes
Why waste $24.00 if you can fix it for 0.00. I did mine on my 2010 base about 3 years ago. No problems with the seals or pads since then. And, no $$ out of pocket. Worth a try since it is so EASY to do.
wideglideleon (04-08-2020)
The following 2 users liked this post by Jeff T.:
OregonMike (04-09-2020),
